Rear SRS Side Panel Removal - How to Remove?
My rear seatbelt seems do not retract smoothly back into the position. I may need to lubricte the mechanism. As far as I know, I have to remove the SRS plastic cap and unscrew a torx screw behind. The seat belt did not twist. I tried it last night but I do not know what is the proper procedures to remove the panel safely.
Please advise, thanks.
Please use only the utmost critical reasoning when diagnosing why the belt is not properly finding its way home.
Two possible scenarios: 1) There is debris lodged in the panel that prevents the belt from retracing as intended. 2) The seat belt retractor defective.
If upon inspection you discover a gift deposited by a passenger, you will have found the source of the trouble. Please do not attempt to lubricate or otherwise meddle with the retractor. The ETRs are a very sophisticated and expensive part. Their proper function is imperative to realize all of MB’s designed-in safety and the extra margin of protection it provides the passenger they restrain in the event of a mishap. If the retractor is defective, address the problem with your dealership’s SA (or management, if nessesary) to replace the ETR under warranty, or for goodwill. Faulty occupant safety hardware has needlessly sacrificed lives and cost manufacturer’s millions in court. Appeal to their sensibilities to fix it ASAP.
Please let us know how you get this squared away.
Thanks.
