Rear Brake Wear ?
Old Jan 31, 2008 | 10:40 PM
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
Rear Brake Wear ?
I just went thur my service invoice records. I have replaced my front brake pads every year around the same time ( March / April ). I am hard on the car, so I must be brakeing a lot. and the last time I replaced the front rotors as well. My question is, I never had the rear brake pads replaced. It's a 2003. No issues, but I should probably have checked out. Any suggestions why the rear breaks last 5 times longer than the fronts.
Old Jan 31, 2008 | 11:15 PM
rlee02135's Avatar
2004 C32 ///AMG
the front brakes do most of the braking...
Old Feb 1, 2008 | 02:03 AM
benzO320's Avatar
1996 E320
Notice your car dips in the front at least a tad bit considering you said you are hard on your car...
All the weight of the car is shifted to the front
Add 2 and 2
Front brake pad wear.
Old Feb 1, 2008 | 08:30 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Front brakes provide 70 to 80% of the total braking force, depending on car type and other variables.
Old Feb 1, 2008 | 08:56 AM
bumpnzx3's Avatar
W203 C230SS
yep- most of the work is done by the front. i've got over 140k on my daily driver (not the benz)- and it's still on the factory rear brakes.
