Leaky corner lenses??
Old Feb 1, 2008 | 09:43 AM
fivepointfivev8's Avatar
C55
Ok, I have two little fish bowls for corner lights and cuts juice to the bulbs. I can't figure out how the water is getting in there. I've even replaced the lenses with clears and have the same problem. I'm wondering if its getting in at the bulb holder?? Another idea is to drill a few small holes at the bottom of the lense base to allow the water to drip out.
Old Feb 1, 2008 | 10:19 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Same issue. Im on the 5th assembly on on Right side and 3rd on the Left. Driving me nuts. Dealer keeps swapping. Enough to help force the change to a C63 LOL
Old Feb 1, 2008 | 12:01 PM
C55
Are they covered under warranty? The original passenger side lense had a lot of water in it. I bet the water is coming in where the amber plastic is glued to the housing.
Old Feb 1, 2008 | 12:04 PM
bumpnzx3's Avatar
W203 C230SS
if they are the same as the stock '06 C230- you are welcome to have mine for the cost of shipping. they were on for about 4k miles, then swapped out for clears. i don't think they leak- but the car has never seen rain/snow. no water in them when i would finish washing the car though.
Old Feb 1, 2008 | 12:34 PM
C55
Originally Posted by bumpnzx3
...you are welcome to have mine for the cost of shipping. ...
Thanks for the offer, the C55 uses the CLK corner lights. I'll do some tests with my originals to see where the water is coming in from. If its not the seam, then its got to be coming from where the O ring on the bulb base meets the socket opening.
Old Feb 3, 2008 | 09:22 AM
Yes... Warranty item. Dealer has been replacing the complete Corner Light Assembly due to corrosion. Its happened again on the passenger side. Going in next week for a B service and they are replacing it again.
