A turning point in Mercedes tuning...Performance Supercharger Pulley
Rating: Thread Rating: 15 votes, 5.00 average.
Old 05-27-2008, 07:54 PM
  #651
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by Bikecop
Yes, it is the one that Brandon is testing. I picked up 1lbs of boost and it responds much quicker. Sorry no photos of the intake on the car. I can take one if you want it looks about the same as stock.
Well... presumably, a middle idler pulley (one w/ yellow bearing) that's a little larger will give slightly more belt-wrap around the S/C pulley. Depending on material chosen, it possibly could also be made lighter - both of those things should aid in quicker responsiveness (i.e. less slip and less inertia).
If you made the top ribbed idler slightly smaller, you could make the middle idler larger still, and pick up even more belt-wrap.
Newzchspy - good question... I used to think I understood the way mechanically driven (i.e. S/C'ed) forced-induction cars made boost, but with this thread, the more I learn, the less I know... I get how a smaller S/C pulley raises boost, just like I get how a larger crank pulley raises boost. How a different idler or a third intake panel raise the boost psi on our cars... well, I'm at a loss on that one, but the test results are what they are. Someone smarter than I will have to chime in on this...
Old 05-27-2008, 08:55 PM
  #652
c32used's Avatar
LET C32 2002
Also for all you guys that have the 178 crank pulley and have been waiting for the test of the two together. Brandon installed one on an SRT6 with the stock idler and a Goodyear Gator Back belt(its a 1/2 inch longer) and saw 21lbs of boost. He is going to dyno it tomorrow.
Wow! 21lbs boost
Brandon I hope you are testing it on a C32 with a 178mm in it.
Old 05-27-2008, 09:10 PM
  #653
mrphotoman's Avatar
srt6
Installed mine tonight, took about 15 minutes or so using a strap wrench and I did not need to take off the other pulley.
I let it idle about 5 minutes in the driveway and the belt look fine and then I drove it about 5 miles and the belt still looks fine so I am good to go.
Old 05-28-2008, 12:08 AM
  #654
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
Just installed my intake mod. It's fantastic! I took it for a test drive around my apartment and got next to a Lancer Evolution that couldn't take his eyes off me. When we got to the onramp I just blasted the throttle. It sounded like something only Lucifer could of conjured up.
Old 05-28-2008, 12:21 AM
  #655
amgstyle's Avatar
2002 SLK 32 AMG
hey guys i also got my intake. i installed it as soon as i got out of work. install was really easy. after seeind the vid of the intake on and hearing the supercharger, i knew i had to get this. but after getting it on i'm kinda dissapointed, my new exhaust i installed last week drowns the sound of the intake. i can't even hear the supercharger, all i hear is my exhaust. kinda sucks.
Old 05-28-2008, 01:28 AM
  #656
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Trust me, most of us would rather have your "problem".
Old 05-28-2008, 04:33 AM
  #657
AMGV6K's Avatar
C32 AMG
If 178mm + sc pulley = 21psi, theoritically 185mm +sc pulley should make around 25psi... wow
Old 05-28-2008, 09:43 AM
  #658
c32used's Avatar
LET C32 2002
I think 21lbs of boost is close to S/C max so ideally the 25lbs boost is not a good route...hey but what do I know
Old 05-28-2008, 11:00 AM
  #659
360_iti's Avatar
W203, W211, W219, W212
+1. We need someone to confirm this ASAP. What is the maximum boost that our s/c can safely handle.
Old 05-28-2008, 11:07 AM
  #660
c32used's Avatar
LET C32 2002
I believe AMG Jerry posted it cause I remember him saying something before if not on this thread already...
Old 05-28-2008, 11:09 AM
  #661
c3232c's Avatar
02 c32 99 superduty
Also recieved my intake
I really like the sound and the throttle response is far better. Now I just need to take care of that squeeling noise I have had for a few weeks around the intake.
Old 05-28-2008, 11:21 AM
  #662
360_iti's Avatar
Hmm couldn't find anything about maximum boost. He stated max rpm, but not boost.
Old 05-28-2008, 01:26 PM
  #663
czwhat's Avatar
2003 C32 AMG
You all are lucky I still haven't got my intake
Old 05-28-2008, 01:46 PM
  #664
AirFrcd's Avatar
03 c32
22 lbs of boost is supposed to be max
Old 05-28-2008, 01:51 PM
  #665
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
I would agree...thought it was also a problem with the MAP and throwing CEL's after more boost then that...
Old 05-28-2008, 01:53 PM
  #666
c32used's Avatar
LET C32 2002
Old 05-28-2008, 01:57 PM
  #667
c32used's Avatar
LET C32 2002
If 22lbs boost is max then 21lbs boost from 178mm pulley with S/C pulley is gonna cut it close...I wonder if it can be done safely without throwing CELs and stuff?
Old 05-28-2008, 02:07 PM
  #668
360_iti's Avatar
22 psi AMG-Jerry talked about was his TT kit. Not s/c.
I couldn't find where this supposedly "22 psi" max s/c boost came from.
Old 05-28-2008, 02:09 PM
  #669
c32used's Avatar
LET C32 2002
I say PM Erick,Jerry or Brandon they should know..
Old 05-28-2008, 02:25 PM
  #670
turbo16lbs's Avatar
You guys are all worried about maximum SC speed when in reality you guys should be wondering if the bottom end of the car is going to withstand such high level of boost. Remember these aren't Honda Civic's. M112k engine go for $7k+. I sure as hell won't risk it.
  #671
360_iti's Avatar
OK let me quote this post from this thread:
https://mbworld.org/forums/showpost....&postcount=125
It's a translation from a tuner in Taiwan.
Originally Posted by cnchung
The best way to increase boost pressure is to use either a smaller supercharger pulley or a larger crank pulley to increase the speed of the supercharger, thus forcing more air into the engine. Take C32AMG as an example, the original C32 supercharger pulley measures 74mm, crank pulley, 150mm. You may reduce the supercharger pulley to 72mm, with a crank pulley of 170mm-182mm to get more power. With the installation of a Schrick 272 duration cams and a 182mm pulley, the boost can reach 1.7-1.8 bar (original 1.1-1.2bar). this mod can bring the power of the C32 from 354hp to 450hp...
Are they saying that 1.7-1.8 bar is still tolerable? Because 1.7 bar = 24.66 psi.
Old 05-28-2008, 02:30 PM
  #672
360_iti's Avatar
I have a deadline at work and you guys came up with this discussion..
Old 05-28-2008, 02:55 PM
  #673
Fifth Ring's Avatar
C32 AMG
Can you post a clip. The original clip sounded more like something Electrolux could of conjured up.
Old 05-28-2008, 03:02 PM
  #674
czwhat's Avatar
2003 C32 AMG
I spoke too soon I went out to the mail box and my intake was there. Easy install but I did break the plastic clip on the splitter.
Old 05-28-2008, 03:06 PM
  #675
turbo16lbs's Avatar
Haha. I'll see what I can do when I get off work.
You have already rated this thread Rating: Thread Rating: 15 votes, 5.00 average.
Quick Reply: A turning point in Mercedes tuning...Performance Supercharger Pulley
