A turning point in Mercedes tuning...Performance Supercharger Pulley
Ted
I think you and I should sit back and let some others try the product and report back after a period of time. Sometimes things are just too good to be true. But sometimes the little guy figures it all out!
a few yrs back i actually used silicone and filled in and made the intake on my zuki swift smooth. power went from 85 hp to 86. haha i'm joking but you get my drift. considered doing same to the Y pipe but decied agaist it as if a piece came loose it would damage the s/c.
Brandon. If a pulley is available i'd like to try it on my car. i'll do a dyno immediately to see A/F.
do you think IATs will be too high even with the upgraded HE and 030 pump? winter driving may be ok but summer a problem?
Perhaps Brandon is not saying much due to the competitive marketplace for c32 performance parts? (LET burst onto the scene right around the time he came out with his larger HE).
Ted
1. By reducing it's size one also reduces available surface area for the belt - result is belt slippage. This is what we see on the dyno graph presented by Code3.
2. In order to make smaller pulley, one has to install smaller shaft bearing - thus bearing is spinning faster. Now we all know stock bearings fail regularly. This one will fail even sooner.
In 2001, this was the route I wanted to take and after looking at it from engineering, not emotional - "I am better than everyone else" angle, I went with larger crank pulley. Link is here to original posts going back is here:
https://mbworld.org/forums/showthrea...threadid=18979
There is a reason why all of the tuners, including myself, use larger crankshaft pulley - better reliability and PROVEN results.
The bearing is the same one as stock.. if fact is the OEM bearing. (orange color)
I drove the car for about 20 minutes and response of the engine was better and power delivery was there... I never felt a jerk or sentation that the belt was slipping.
The pulley was engineered smaller but keeping the bearings the same. Also the back plate is pretty much the same as stock..
the only different with this pulley.. the material will be lighter, is not as fat as the stock one and the groves are designed in such a way to make the most contact with a continous grove belt.
I know what slipping feels (E55 with ASP) I had the Evosport set up on my C32.... and the product seem to work just fine.
The magical SC Clutch, is not magical...Its a simple two-piece bolt-on pulley and armature plate. The Code3 Pulley works identical to the stock piece, if not better. We designed it to be stronger. We even gave it a little flare to look cool. We also use a quality NSK bearing.
Check this link out...Toyota MR2 Supercharged with electromagnetic clutch pulley upgrade. This mod is not new or magical. The problem is, most cars don't use this wacky pulley setup. They simply have a bypass valve.
http://autospeed.com/cms/A_2316/article.html
Many people run an "upper and lower" pulley. Check out Cobras or Minis just to name a few. But even though the lower is available, most people stick with just the upgraded sc pulley. In fact, more commonly, if you swap out the crank pulley, you keep it the same size, but purchase a lightweight version. Very common with Minis.
This is all about money, and many people realize that. Some cant seem to bring themselves to believe it though. Don't think that I didn't talk to everyone I could before I even embarked on this project, which included engineers from Magnuson and Jackson Racing. We could have copied a crank pulley like everyone else, and called it a day. But why? Its not the logical way to make power. A company looking to make a quick buck doesn't want to embark on creating a completely new piece. There are 17 pieces to the stock sc pulley. Sometimes modifications are about perception. Sell people a big fancy crank pulley, and you can justify a higher price. Plus, look at all the money shops were making off of installation...Why sell them a piece that they can install themselves. They want to keep it magical.
having tested my car with the upgraded HE.. its a perfect combo.
I hit multiple 3 digit runs 2 weeks ago with this pulley.. no power loss or sluggish performance.
The heat exchanger will handle this pulley.. where its LET or Code3.
Weather was mid to high 60's partly cloudy..
clutch pulley alone with stock pump and HE probably won't be good for summer weather in so cal.
We discussed this issue briefly last year. To address your points.
1. The altered wrap angle (arc of contact)of the smaller sc pulley, versus the stock one, is so minimal, it hardly registers mathematically. I can assure you that the pulley grooves were belt matched for the best grip, while maintaining belt reliability and proper geometry. After 6000 miles, I see no signs of slipping, cracking, tearing, or deterioration of the belt. It looks as new as it was when we put it on.
You are not seeing belt slippage. All of my stock dynos show the same behavior, and the belt is not slipping in them either. If you are referring to any large dips, those are simply operator issues. Looking over many crank pulley dynos, I see the same behavior. Here is an ASP crank pulley dyno.
Those that have driven my car, driven their own car with my pulley, and dynoed the vehicle have reported no slippage. Nothing but perfect engagement from any speed and any gear. One of those people was a former Evosport ODPS customer.
2. Unfortunately you are incorrect. The same size bearing is used, and it is sourced from NSK specifically for this high speed application. Failure rate will be no less than the stock bearing.
I respect all the work that you have done and still do. But in talking with engineers from both Magnuson and Jackson Racing/Moss Motors about the project, both before and after R&D, they agree, this is a solution that works great. There is a reason I went outside the MB circle of tuners to get this developed...
I would say test the unit when it comes out.. ( you can swap from one car to another) in matter of minutes. and if you feel its not for you then its your call.
Reading the 335 forums they had the same critism for Terry. An amateur tuner who developed the Juice Box.
The juice box under cuts everybody and with a few additions of "H pills" basically transistors that add boost.. it has as much power as the big tuning places and with less "CEL" and boost issues. He also has a racing switch you can add on.
In fact Terry holds the fasted 335 on record with his project JB2 HH R.
His product sells for a few hundred buck...
sometimes we over think things...
do you sell the NSK bearing seperate? I have the Houston bearing replaced the original bearing, but that only lasted 6months. i'm on my second houston bearing. it'll be nice if you can sell the NSK original bearing. If you do then I will sell my spare houston bearing I recently purchased for the NSK to be the spare one.
Unfortunately I can not comment on why previous prototypes may have failed. I freely admitted in the beginning that we had some belt slip, but with the guidance of companies that produce superchargers and pulleys, made appropriate changes. Believe me, with the first few versions of the pulley, it slipped, and I didn't think the project had much hope...All it took was some good advice from people in the industry, and we were off and running.
Thanks for all the info so far!
Curious about your comment regarding belt slippage... does the stock S/C pulley slip a little, and this one slips a little more (but still a low, acceptable level), or does the stock one not slip at all, and this one slips slightly, albeit at an acceptable level? I really don't know enough about the stock S/C pulley and clutch to know the answer...
TIA! Keep the info comin'
.........Like others have asked, is the s/c clutch issue just an urban legend? Or is it the case that when the belt slips with the smaller s/c pulley, it behaves like a bad s/c clutch engagement? Tholse of us laymen are very confused.
Ted
Ted
maybe ribs were added to the pulley or some kind of pattern were added to prevent slippage of the belt.
Thanks.
