For You Guys That Went 255's
Old Mar 26, 2008 | 08:05 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
I am planning on trying 255-40-17 and 235-45-17 on my stock C32 AMG rims. I know the side wall will be taller than what they are for the 245-40 and 225-45.
So my question is was it noticable with the eye the difference in height with the 255's and the 235's over the stock set up?
Second question is am I really gaining that much more traction with bumping up to the 255's? Also from the rear will the 255's really show a noticable difference in width when looking at it from behind. If not I may just stick with the stock set up. If I am going to get a lot more trac and a nice wider stance from the rear I will pull the trigger on the 255's.
Thanks All
Old Mar 26, 2008 | 09:03 PM
e1000's Avatar
a quarter mile at a time
1.3% difference, you should be fine, although someone here may have tried the sizes.
Old Mar 26, 2008 | 09:11 PM
360_iti's Avatar
W203, W211, W219, W212
To calculate the difference between the two, do this math:
255-40-17 sidewall = 40% x 255mm = 102mm
245-40-17 sidewall = 40% x 245mm = 98mm
Only 4mm difference in sidewall height, but the overall diameter difference is 8mm. Not a big deal if you asked me.
Regarding the tire width appearance from behind, I'd say 10mm is noticeable. But it also depends on the brand. One thing that I know, Nitto tires always look wider than other brands within the same size, due to its sidewall design.
Old Mar 26, 2008 | 10:15 PM
Illegal Machine's Avatar
'10 P30 C63 AMG
You should try 285's....
Old Mar 26, 2008 | 10:45 PM
e1000's Avatar
285's won't fit without surgery
Old Mar 26, 2008 | 10:49 PM
redfarsi's Avatar
04' C32 AMG & 90' TT 300ZX
I tried 9.5 inch wide rim in the rear with 285's. The tires were way to wide. No go, although I heard that same rim with 255's should be fine.
Old Mar 26, 2008 | 11:58 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
When I had my C32 I went with the following on my stock 17''s:
Tire type: Falken - Azenis 615s
Front: 225/45/R17
Rear: 255/40/R17
"So my question is was it noticable with the eye the difference in height with the 255's and the 235's over the stock set up?"
---- The fronts were still the stock size no difference there. I don't think there was a very noticeable difference in height in the rear tire size over stock. The best way to describe them were "beefy"??
"Second question is am I really gaining that much more traction with bumping up to the 255's?"
--- Well, there was an improvement over the stock size Hankook Ventus K104 I had on. The Azenis are a pseudo track tire...
"Also from the rear will the 255's really show a noticable difference in width when looking at it from behind. If not I may just stick with the stock set up. If I am going to get a lot more trac and a nice wider stance from the rear I will pull the trigger on the 255's."
Yes! Between the size increase on the rears and one of the most crazy tread patterns I've ever seen on a tire I was quite pleased.......
Here are some pics and you can judge for yourself:
Attached Thumbnails For You Guys That Went 255's-car-004.jpg   For You Guys That Went 255's-car-003.jpg
Old Mar 27, 2008 | 06:42 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Thanks All
I have them in Brigdstone 050 PP's on my car. You won't notice a thing my friend. Other then it sticks BETTER, and LOOKS better in the fenderwells. Espically from the rear, which is what MOST people see
See yeah
Old Mar 27, 2008 | 08:18 AM
Hjartarson's Avatar
2002 C32 AMG
I have 255/35 18", no problems and they look great!
Old Mar 27, 2008 | 08:42 AM
bud4ya's Avatar
Why did you decide to keep the 225's on the front? I am just curious. I just trhough out 235's beause I was increasing teh size in the back.
Front: 225/45/R17
Rear: 255/40/R17
Old Mar 27, 2008 | 10:14 AM
timberman's Avatar
silver 2002 c32 amg
I went with this exact set up!
tyres used were goodyear eagle F1' GS D3's and I had no problems with fitment,
there's little difference height wise and my speedo still reads over slightly ( GPS verified).
I would say that the grip improved a little on the rear and there was a notable increase in tyre width, but I found that the fronts rubbed slightly when taking tight turns especially when leaving my drive which I found annoying so I recently changed them back to the stock 225's.
incidently the tyres I am now running on are Goodyear eagle F1 asymmetrics and are supposed to be a replacement for the eagle F1's DS G3's over here in the UK .
I don't know if their available to you guys in the US but If they are you should try them,
these are easily the best tyre I have ever used
Old Mar 27, 2008 | 10:32 AM
bud4ya's Avatar
So there is no noticable difference in handling and ride if I just stay with the 225's on the front and 255's in the rear. Probally save me some money too.
Old Mar 27, 2008 | 11:22 AM
wawy's Avatar
"Why did you decide to keep the 225's on the front? I am just curious. I just trhough out 235's beause I was increasing teh size in the back."
Because it was lowered more in the front than in the back and I wanted to avoid any rubbing issues. You should note though that increasing the width in the back and not the front could increase understeer....
Old Mar 27, 2008 | 11:52 AM
bud4ya's Avatar
Thats the input I was looking for TY. So if my car is not lowered and I change the back to 255's it is a good idea to change fronts to 235's it sounds like.
Old Mar 28, 2008 | 08:53 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
I just recently replaced my OEM rear tires with Goodyear Eagle F1 All-Seasons in a 255/40-17. IMO, the 255's look better as they fill out the wheelwell more, and don't have the stretched on look that the OEM Michelin 245's had. Here is a thread where I posted pics: https://mbworld.org/forums/showpost....&postcount=119
You definitely notice the difference in width when viewing the rear of the car.
Old Mar 29, 2008 | 12:21 AM
c32used's Avatar
LET C32 2002
I have new Kumho 225 17" fronts and 255 17" rears on my summer setup...currently I am using 235 all around and my front tires do rub only when deep cornering.
Old Mar 29, 2008 | 07:42 AM
bud4ya's Avatar
C32used what model Kumho do you have? There were many to choose from at pretty low price on discount tire. I want something that grips cornering and mashing the gas. Plus something that is good in the rain and is not noisy. I guess I am sounding like the guy with the champagne appetite and beer pocket book.
Old Mar 29, 2008 | 07:45 AM
bud4ya's Avatar
Thanks pics are always great. When I had my 265's on my BMW 540 you could really a nice stance from the rear. I know the rim is not as wide on the MB but the 255's has to look better than the 245's
Old Mar 30, 2008 | 12:21 AM
c32used's Avatar
LET C32 2002
Kumho SPT
