New Mods
i was just about to ask what that switch was in the 3rd pic. nice setup for V1
and the price is $340 USD shipped (I'm in Vancouver, Canada)
It is a simpe plug-play swap.
After about an hour drive today, here are some observations:
1. The digital screen matches the audio screen a lot better than the original one.
2. All the buttons illuminates when pressed, however I don't know if the charcoal filter and rest function work. Base on previous threads on this topic, I dont think the charcoal filter works. Can anybody tell me what'd happen when the REST function is turned on?
3. A few members who have done this mod said that the fan direction control on the passenger side doesnt work, however, I found out that it DOES work under one circumstance: when you turn the AUTO function on, then you turn the direction control on the passenger side, it will control the fan direction of both driver and passenger side. However if you turn the one at driver side, it will override the passenger side one and the passenger side will not work until you press auto again.
4. I just went to my garage and tried the secret menu mentioned above, and its quite a cool feature. I did a quick search and found some partial list of the functions. Does any one have a complete list?
6. I noticed that there's a spot on screen that says "MAX", however when i switched the fan speed to the highest, the "MAX" wouldn't illuminate.
5. There's an issue with this mod tho. It raises the chance of getting into an accident. I noticed that during my 1 hour drive today, I looked down every few minutes- almost ran a red light. Whoever wants to do this mod should aware of this.
I can not see options like the charcoal filter working unless it was installed and the system totally upgraded - I would think you only have the standard paper filter located by the battery...which itself seems to have been upgraded with a charcoal or fine filter coating...
REST is for when you have the car off in the winter and you want to use the block water to keep heating the cabin. Pressing REST while you run into a store or make a trip, leave some one in the car utilizes the cars water and heat to maintain (up to 20 minutes or a half hour) some comfortable heat in the cabin.
Thanks,
Jake
press it while the ignition on will turn the a/c compressor off. at least it's the case for 01-04 since we don't have the individual OFF button
BTW I assume there is a way to change it from centigrade to Farenheit in the hidden menus or by coding???
I'd also like to know a few more things about the install;
-Do you need the dealer to recode anything or can degrees F/C be set by the "secret menu"?
-What is involved in removing the panel?
Press OK + 7 + mute for 5 sec. I can't figure out the engineering mode keys though anyone know from there? I tried many and they didn't get me there.
