!!! LETMotorsports Cams !!!
Erick provided great service as always.
I am running the 185 and dont have very much boost room left...
What's code3 sc pulley size again? 65.8mm?
Using LET 185mm, it turns out to be 185 : 65.8 = 2.81155 ratio x 7000 rpm = 19,680 s/c rpm. Scary, but still below the limit.
Or better yet, use 181mm - 181 : 65.8 = 2.75 x 7000 = 19,250 s/c rpm
I guess time will have to tell..
I'm almost sure you can safely put 185 crank + 65.8 s/c as long as you don't go above 6200 rpm. That would put you well below the 10% off of your s/c rpm limit.
The sound would be awesome tho !!
PS: just realized you also have a white C32.
That could be the case....I overboosted when I was dragging....
It does sound freaking incredible as it is now...!!!
What were you doing when you hit overboost? What speed, gear, rpm...
You could always run a MAP clamp to avoid this problem but it is a band aide and you will not be adding any more fuel.
