SL55 rims on C55 = DONE
http://www.autotrader.com/fyc/vdp.js...standard=false
What's the bumpers on this one btw?
I have 235/ 275 combo stuffed under the car with Koni Sports. Big difference on the track but I want more!
The result is rediculous looks and HUGE increase in handling with zero rubbing, no use of spacers or ANY issues. I gained 1 inch of track front and a hair more rear, .5" of tire section width at each corner, and it is neutral and turns in amazingly due to the roll center changes. It does however ride a bit harsher having 225/255's on instead of 235/265, but the turn in response and directness is HUGE.
Before anyone makes improper comments the offsets are what AMG peformace salon suggest, so what's good for the safety car is good for me. Positive comments only please.
I Just did a canyon run and had to lower the rear pressure 1lb because the front was gripping so well! 36 all around cold is perfect on 225/255 RE01R's. The turn in is out of hand. Where the c55 used to be a pig in slow speed corners now it is more P car. I easily gained 20mph+ in ANY corner.
Check it out:
285/30 smaller diameter than 275/35
25'' compare to 25.6''
in slick 24.8
for the next autocross season I would like running 255/35 front and 285/30 rear or 245/35 and 285/30 in slick
I'am not sure if will I go with slick or street tire
with c55 if you will go fast in autocross you need large tire (I think)
in slick 24.8
I moved on to a 944 Turbo track car and left the C55 to the wife.
