JUST FINISH MY HEADERS;;
Old Jun 1, 2008 | 01:55 PM
Mikegpr03's Avatar
C63
That welding is second to NONE! WOW Please consider making some C55 headers you will have my money thats for sure.
Old Jun 2, 2008 | 12:28 PM
DANIEL.C's Avatar
W203 C32AMG T-MODEL&w202 c230kompressor
KIND DA BUSY LATELLY!!!OTHER CLOSE LOOK!! EXT ITS JUST AN status, a/f ratio its the correct way to make a tuning!!!
Attached Thumbnails JUST FINISH MY HEADERS;;-img_0021.jpg   JUST FINISH MY HEADERS;;-img_0036.jpg   JUST FINISH MY HEADERS;;-img_0039.jpg   JUST FINISH MY HEADERS;;-img_0042.jpg   JUST FINISH MY HEADERS;;-img_0043.jpg
Old Jun 2, 2008 | 01:22 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Hello, this jig has four holes......I wonder why?
I see some 55K headers coming soon......
Old Jun 2, 2008 | 01:23 PM
///AMG4EVER's Avatar
CLS55 Designo 030
PM sent.
Old Jun 2, 2008 | 01:26 PM
SteveL's Avatar
C43, SLK32, CLK63 Black Series
They are extremely nice but I noticed that there is no primary cat. I see the oxygen sensors built into the collector. Without a cat, how will you prevent a check engine light?
Old Jun 3, 2008 | 11:24 AM
DANIEL.C's Avatar
CAT ITS NOT A ISSUE IN MY REGION!!there its 2 O2 at front 2 at REAR<<u can disadble the o2 signal at the rear by using the special version of the star DIAG,the engine immo will functional & without flash due to the O2,,(just turn it off by using DIAG haha no--this its the wrong way!!!!!)
Old Jun 3, 2008 | 11:25 AM
  #32
DANIEL.C's Avatar
let me send u some pics bro!!!!
Old Oct 26, 2008 | 11:03 PM
  #33
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
yeah, its been a little while, but wow, great work. can you pm me some info on what it cost you and how much work you personally put into it? Thanks!
Old Oct 26, 2008 | 11:37 PM
  #34
Eleventeen's Avatar
2002 C32 AMG
About 7,634 times nicer than any exhaust work I've ever done in my driveway!
Old Oct 27, 2008 | 12:53 AM
  #35
SilverBulletAMG's Avatar
C32 AMG
It's an old thread but wow! I want sounds clips of that bad boy.
Old Oct 27, 2008 | 11:01 AM
  #36
240M3SRT's Avatar
CL 600
Very nice.
What was the price? That looks like about $3000 minimum.
Old Oct 27, 2008 | 12:32 PM
  #37
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
well done!
Old Oct 27, 2008 | 01:46 PM
  #38
Mikegpr03's Avatar
C63
Every time I look at those pics you can tell that alot of time and love went into that setup.
Old Oct 30, 2008 | 01:27 AM
  #39
BrianBrave's Avatar
SRT-6
Originally Posted by MarcusF
I'd like to know a little more about this. How can someone tune an engine with an EGT? How does one determine what the *right* temperature is? If I retard the timing, the EGT will increase. Advancing timing will lower EGT. However, that doesn't tell me which timing change results in a higher power level. Changes in the A/F ratio affect EGT as well. Without a different measurement tool, such as a dyno or a qtr mile trap speed, how would I know what is better?
Also, I've owned several rotaries. Rotaries have much higher exhaust temperatures than their piston engined counterparts. It's common for a rotary to produce an 1800˚F exhaust temp. Nothing melts. What would melt on a street driven piston engine?
Pilots will tweek their engines in flight via leaning or riching the AFR via a an ECT gauge (and a good pilots ear) when increasing and decreasing altitude. (density air pressure)
