JUST FINISH MY HEADERS;;
!!finally its been done equal lengthheaders!!!awsome!!sharing with u!!!!! exh temp make lots of difference!!
i were using stock header without cat(4 total) in full load temp can reach up to app 900~1000 degress!!!now no more then 500 degress i were shock(the sensor its in the same same position as always!!!
haha, jees, there are so many welds I can't even count them, they could have saved alot of hassle by just using a mandrel bender. Anyways excellent job, quality is definitely impressive, thats definitely a pricey setup and not for 90% of the drivers out there but very nice for the extreme performance enthusiast.
yaya me personally really digging with the welding coz its feeling hot
& sporty
wanna push it no doubt!!!totally differ from the bender(but the fact its bender just can't provide the exact angle u want so doing by the old school way its the only solution!) the setting of my exhaust headers as att pics using 42.7mm tube---mid section 63mm------rear section 76mm, the muffller its striaght 2 piping out!!! with out any cat & disable the rear O2 signal!!!no immo problems!!(its fully custom made by the pros head to end!!!!)
as the ext temp i using DEFI to monitor it, its good to know that the temps during the fullload range!!!onece i got more develop pic from the pro i will post it asap,, so every knows!! an good stuff trying to share!!!!!!everyone cares the dyno run result the thing i know its take off the cat it can gian 15~20hp+ more so with its setting now should be more!!!i will do an run & let see how it rolls hahaha
ot: Daniel, is that an Akita in your sig pic?
)Last edited by mkonei; May 31, 2008 at 07:48 AM.
Also, I've owned several rotaries. Rotaries have much higher exhaust temperatures than their piston engined counterparts. It's common for a rotary to produce an 1800˚F exhaust temp. Nothing melts. What would melt on a street driven piston engine?
first piece i googled. its not meant to be an all encompassing method to tune, just an aid. rotaries are a totally different game all together.
