Window & sunroof not working well
Old Jun 7, 2008 | 04:36 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
Since I got he car back yesterday I noticed the one window does not go auto up and the sunroof will not shut or open right. I have to hit the sunroof button 50time to get it to open any ideas?
Old Jun 7, 2008 | 04:51 PM
calimax's Avatar
RENNtech C32 AMG
With the windows closed, open 2 at a time. Hold the window buttons all the way down (second click) from the closed position to the open and continue holding down for 15 sec once opened. repeat the same for closing and for the sunroof. Also take the car to Auto Zone and have them check the battery, low voltage can cause problems in our cars. or just call me and I'll check it out, I can't trust some of the dummies there.
Old Jun 7, 2008 | 05:34 PM
hooleyboy's Avatar
C55,SL55,C63
Maybe we can check it tonight before we head to the track?
Old Jun 7, 2008 | 06:16 PM
c3232c's Avatar
02 c32 99 superduty
My car did the same thing after I unhooked the battery, I am pretty sure it tells you how to reset everything in your owners manual. I am stoked to see what your car will run!!
Old Jun 7, 2008 | 07:16 PM
hooleyboy's Avatar
C55,SL55,C63
My hopes are high on a good run but i wont be upset if in dont meet my number. is going to be in the upper 80's and dry very dry at the track.
Old Jun 7, 2008 | 07:40 PM
hammertime21's Avatar
2002 C32 AMG
just hold each window switch till window hits lower limit and hold 3 seconds, then put window all the way up and hold switch for 3 seconds. do this for each window, and it will be OK. then for sun roof, once roof is all the way back hold switch 3 seconds, then move forward and hold switch 3 seconds, then put roof in tilt up postion and hold 3 seconds. then everything will be synchronized.
Old Jun 7, 2008 | 07:42 PM
hooleyboy's Avatar
C55,SL55,C63
problem fixed
Old Jun 13, 2008 | 01:26 AM
c32used's Avatar
LET C32 2002
I've done this but basically only the down or up and hold for three seconds on the sunroof I got it all the way back and held 3 seconds and then forward and held 3 seconds thats it. If you didn't mess with your battery at all I say have it checked may be you are losing power somehow
Old Jun 13, 2008 | 07:34 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I'm sure they would've unhooked his negative battery terminal before changing his crank pulley... I've had the same thing happen (one-touch up feature on windows stops and incorrect sunroof operation) on both my w203's, after disconnecting the battery. I've never done anything to proactively "fix" it, because everything returns to normal a few days later (for whatever reason)... so I've just lived with it while it's happening. It is pretty annoying, though.
