Just Ordered AMS Pulley from LET.
Kleemann: Autorotor "same as Kenne Bell"- 2.4 litre, 4 male, 6 female lobes. larger bearings. High Boost
Renntech: Lysholm "same as Whipple" - 2.0 litre, 3 male, 5 femial lobes, smaller bearings. Mid Boost
AMG: IHI "Japanese clone of Lysholm",
OEM-4 Cylinders: Eaton "Roots Style" least efficient.
That was why I decided to go with a used Kleemann ($7-7.5K) instead of a new Renntech ($15K).
hooleyboy, you might want to consider udp's at the same time - combined with the AMS pulley, you should notice an even better bump in rwhp and rwtq.
I think LET makes underdrive pullies for N/A cars - you should check with Erick, if interested. If they don't, I'm pretty sure evosport makes them for your car - so that would be an option.
Thanks for sharing all of your mod info so far - sounds like it's turning into quite a beast
Why did you order an AMS PULLEY FROM LET, instead of just getting it straight form AMS. Btw, AMS isnt very legit, their rep is really low, they copy products from other manufacturers.
Second question. Why mod an NA? Its so expensive and the gains are so small.
So yes in an extreme case removing rotating mass will enable more torque for acceleration, hence why light weight flywheels are popular. This effect is most noticeable in light weight cars with hi revving engines and little torque to start with - ie race cars and the like. On 3000lb + road cars the effect is minimal, especially when you have a V6 or V8 with gobs of torque to start with.
But my beef is with the bogus 10HP increase and improved mpg - a light weight pulley does not help, nor does a light weight flywheel.
In fact I've never seen anyone claim hp or mpg improvements by using a light weight flywheel, much less a light weight pulley.
This topic has been beat to death on the other MB forum.
maybe a bad choice of words, but you're right, he's getting less slow day by day. I meant as opposed to going to Kleemann like Dragon did and just getting the whole shot done in one trip.
