Code3 SC pulley plus 178mm, any updates?
Srt-6 Crossfire
I thought there was at least one person running this setup and an SRT6 that was supposed to be dynoed? Can anyone shed some light on this?
C32, Cobra, 700hp Vespa
2002 C32 AMG
Unfortunately, I haven't been to the track yet. I ran a 12.8 @108 with ASP (all four cats removed) only. It was probably about 50*F when I ran, so running in the dead humid heat of summer wouldn't do the mod justice. When it cools off a bit, I will go back to the track, but keep in mind I also have the Code3 H.E., Code3 intake, K&N's, and a tune now, which were all added after my last track day, so I won't be able to report definitive results from just the addition of the upper pulley. When I go back, I'll post up.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2002 C32 AMG
I forgot to mention that I constantly get a CEL (P0108 - MAP sensor high input) due to the high boost. If you bring it up to full boost a few times, it comes on. If you don't get on it too much, you'll probably be okay
I don't even bother resetting it anymore![drive](https://mbworld.org/forums/images/smilies/driving.gif)
This can be cured with a MAP clamp and re-tune, but I need to get it on a Dyno first.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
I think it will help reducing the 22lb spike.
500E Signal Rot
Yes a MAF clamp will take care of the problem
It is simply a resistor that is added on the signal wire of the MAF sensor. It's job is exactly as it sounds- it's "limiting", or clamping the signal voltage to ensure it does not exceed the Mercedes-Benz specification. The clamp is basically just a rheostat- an adjustable resistor. We will typically put between 490 and 500 ohms of resistance in, which limits the MAF signal due to the increased airflow from the supercharger. Here are the specs. you'll want to see:
At idle, normal operating temp, the voltage on the MAF signal wire should be 1.32 to 1.35 volts.
At wide open throttle, you do not want to exceed 4.75 to 4.77 Volts.
2008 A8L, 2002 996TT X50, 2009 X5
2002 C32 AMG
W203, W211, W219, W212
2002 C32 AMG
Exactly. Last time I ran it was about 50*; nice and cool for making power. Right now its about 85+ so running in this heat will kill a lot of the gained power and wouldn't be an accurate comparison. I didn't do any baseline runs in the heat.
1 Post
2003 C32 AMG, 2003 E39 M5
Could you speculate ¼ mile and trap speed with the combo? I wish someone had a dyno sheet that was running both pulleys. I thought Brandon had one on here but my eyes got tried reading.
I was speaking with a guy on the Audi board and he showed me a vid of his stage 3 B5 S4 just putting car lengths on a C32 with crank pulley, intake, exhaust and tune. I told him there is a new S/C pulley out that can be combined with the crank pulley for some nice gains. I told him I am not sure if it is in stage 3 S4 range or not but I would find out.
So I guess just looking for 185 pulley and S/C pulley setup #’s like a couple others here.
There is always a faster car out there....
1 Post
I think it maybe from the pics in his gallery. This was the link he sent.
http://www.youtube.com/watch?v=gKoSQHrtBfY
1 Post
Oh ya I totally agree. I was just trying to give him and idea of what the C32 would do 1/4 and trap speed with these mods. They were thinking the C32 still only had the crank pulley option.
2002 C32 AMG
Don't get me wrong though, the car felt a lot faster after the upper pulley & tune, even in the summer heat (getting used to it now
Srt-6 Crossfire
Well I finally made it to the track with my 178 and Hoosier drag radials. I am very pleased and can only imagine how bad *** it would be with a Code3 pulley added on. I think I'm gonna try to get her into the 11's without increasing the boost though. Patiently awaiting the release of Needswings intake manifolds. Please update if anyone runs the pulley combo at the track.
