No Stereo or Nav Audio after battery disconnect- what did I screw up now?
02' C32 - 07' H2 - 07' BMW K1200R
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Just posting this fast before leaving, did not have a chance to search properly. I will check back into things later tonight.
I had to disconect battery power to the car the other day to do a little work for a few hours.
After reconecting the power, I no longer have any audio coming out of the Sound system or Navigation.![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Checked all relevant fuses (I think) - and replaced them to play it safe.
Still nothing....Everything still works as it should, there is just no audio (and it is not on mute)![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Only thing I can think of is the Amp is shot (or I goofed it up somehow).
Any troubleshooting ideas?
Thanks?
Thanks?
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Maybe the Audio and Nav just didn't reset properly after reconnection of Batt. Try doing it again and if don't work try going to dealer to see if Audio/Nav is turned off on star menu....that may be ur issue....I had to get audio and nav set to off after I replaced my Nav unit to the one I have now.
Thanks!
I guess I am going to have to make a trip to a dealer, nothing I have tried has worked yet.
My only guess is that the amp has gone out - or I snagged and pulled loose a critical stereo system wire/connection when routing the radar detector, laser jammer, scanner, and secondary GPS wires through the car somehow.
I can not remember for sure, but it is possible the sound system was powered up (but volume very low) when I cut the power, and still "on" when I powered everything back up.
Maybe that could have zapped it?
I will see if I can find a stereo wiring diagram somewhere and see if a critical line is located anywhere near the area I was routing wires...
