Trunk locking using mechanical key.
a car that can't do the throttle reset.
First, I checked the manual... basically I can lock my trunk with the mechanical key, but I cannot remove the key when turned to the locked position. Its weird. Has anyone run into this??
Just to be clear.. the trunk's manual lock for when you valet and don't want them getting into the trunk is what I am talking about.
no. you should be able to remove the key. make sure its fully turned to remove it. i havent had a problem to remove it. you can also do this to the glove compartment and the drivers door, though the latter is kinda useless.
ive noticed that the truck locks can be a pain in the butt sometime. i think part of the problem has to do with the tiny key. ive had some i had just had to wiggle the key around alot to get it to work.
