My weekend...how to make a fast car faster
Would nitrogen work well in an application like this??? Even more cooling?
Do you have to run a cryo kit post air filter or pre air fliter or dose it not matter? I would bet In Arizona in the summer when temps are around 100 degrees at 9pm you could get back some time lost due to bad race conditions.
Do you have to run a cryo kit post air filter or pre air fliter or dose it not matter? I would bet In Arizona in the summer when temps are around 100 degrees at 9pm you could get back some time lost due to bad race conditions.Just thinking out loud......
You'll drop inlet temps significantly if you use the OEM inlets above the radiator that take in ambient temperature air.
The system is multifunctional. The stock air inlets are still feeling air to the LET intake which in itself pulls in a conciderable amount of air over the stock system. The air then goes over the cryogenic chaimbers that are located in the intake and cooled once further by the nos that is injected into the throttle body.
The fuel also gets pumped through a chilling device and the heat exchanger is misted with liquid co2 as well. The c02 gets the devices -80 degrees, and removes the heat from the air/liquid going through it.
So whats the good word have you tried it out yet? if so how do you like it? When you get use to it and have a chance to mess around with the cryo kit make sure to post your thoughts.
Did the throttle switch for the cyro kit get into the why of the gas peddle throttle button?
I have the LET plugs/wires. I will pretty much only use the system at the track when I am also running race gas. The ZEX system also supplies gas to the nozzle.
I am not a fan of having anything near the gas peddle when driving, expecially with this much power in the car.
As most of you know, I tested the nitrous setup for many months and I strongly feel that anything less than a 100 shot will be perfectly safe.
As a precaution, we wrote a specific tune for the car, with some timing pulled on the top end. With the addition of 100 octane fuel, timing retard, and the Cry02 system, I feel that the setup is 100% safe.
If you are considering nitrous, just remember to choose a good kit, take your time installing it, and add some barriers or safe guards.
Good job, Jake!
We are rooting for you to be the first C32 in the very low 12s.
I think you need to seriously consider a Quaife unit.
Every time I figured I was done modding either you or Jerry start something new and confuse me...........I don't forsee the Cyro but the Zex maybe a winter project
depending how you do on the 18th...
Just let me know "if" / I mean when your gonna do the ZEX. There is some additional plumbing pieces to make it work on our car.
Would love to mount the purge facing out the front and blast people as they walk past..... Maybe make it to lift skirts???
Now Vic and I are feeling some real pressure in the Chicago contingent!!
Now Vic and I are feeling some real pressure in the Chicago contingent!!I will have some hard numbers next weekend at the track and I think that will be your basis on if it will work for you.
ZEX rules...just the install is a PAIN!
As always, I will keep the rear view camera on during our runs to make sure your ok back there......
