what are the beniflts of having an x-pipe?
Former Vendor of MBWorld
C55,SL55,C63
what are the benifits of having an x-pipe?
So I'm trying to shop for some standard exhaust stuff for my exhaust project i got in the works. I think I got the cats taken care of. Now i'm wondering what should i do for an x-pipe. Do I need one? Can i pick one off the shelf and be done with it? Any help or ideas would be great. do x-pipes just help mix exhaust?
2003 C-Class Sportcoupe
'06 E55, W204 C350, '04 Carrera C4S, '02 ML55 (Wife's)
I saw no HP gains from removing my resonator/H pipe at least down the strip…. But the exhaust note was better from my perspective with not much resonance change
The X-pipe was a worth while mod for the price! For me at least...
C55,SL55,C63
An x pipe is just a type of balance/crossover tube. It helps to equalize the pressures between the left and right cylinder banks. Your car should already have a H type crossover tube. An X pipe will have a different exhaust note, probably louder, and will a better scavenging effect than an H tube. The exhaust gases shuffle down the downpipes and merge at the X pipe; the gas exiting the x pipe will move faster than the gas entering the x pipe, hence the scavenging effect. You might lose a little back pressure with an X pipe. Overall, you probably have a louder different exhaust note than an H pipe and maybe 5hp gain.
C55,SL55,C63
would any old 2.5 inch xpipe do the trick as long as it fit?
Sorry no video clip of mine (sold it) but here is a link to another’s resonator mod…
http://www.youtube.com/watch?v=TdOdxr-Oybo
http://www.youtube.com/watch?v=3hO336BW1U0
http://www.youtube.com/watch?v=YrKYEvd9Xvg
I think removing the secondary cats is a good start. The 100 cell primary cat may turn on some check engine lights unless you get the ECU reprogrammed with a specific tune… Most tuners tune with 200 cell cats to my knowledge… I’d stick with 200 cell cats. I removed the secondary cats from my Porsche and replaced the primary’s with 200 cell and no codes!
I’m a little confused with your x-pipe / duel exhaust… I think you either have to have an x-pipe system or true duel exhaust…. I’d go for the x-pipe system
I don’t remember what the C55 pipe i.d. was but 2.5” seems a tad bit larger… but to each his/her own.
C55,SL55,C63
I already have the res-delete and no secondary cats. After removing secondary cats i picked up 13whp and 19wtq with same day dynos.
here is the linkhttps://mbworld.org/forums/c32-amg-c55-amg-w203/263590-secondary-cats-removed-dyno.html
That's some great numbers on the dyno for those two mods! like i said i did the same but it didn't show on the 1/4 mile....
maybe my car was too new and wasn't broken in or something?
ok.... cool i know what you mean buy the duels.... I seen a few do the intake kit and gain 4-5 mph and a tenth (with the exhaust mods)
Nice sound clip by the way.... How does it sound driving away? Must be sweet!
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
C55,SL55,C63
