C55 performance parts list.
Support the Sponsors of this site
There is more options to modding this car than just the big companies. Mbworld.org has a bunch of sponsors on board that make great stuff. Most likely you have never heard of them, as I didn't know when i first joined.
Headers: EVOsport, VRP Tuning, Kleemann, RENNtech, AMS Motorsports, all make headers for the C55
Kleemann headers are the only ones (as far as i know that are not direct bolt ons) I Have Evosport headers and I like them alot. Prices range from about $1600-$5000 just for headers. With gains around 10-20hp
Software/ECU: EVOsport, LET motorsports, VRP tuning, RENNtech, Kleemann, Brabus, Powerchip, all offer some form of ECU upgrade for the C55. expect somewhere around 20hp give or take a few HPs.
Intake/Airbox As far as i know RENNtech and VRPtuning are the only ones who offer Airbox/intake mods for a C55. I think Brabus does too but I think its alot harder to get. VRPtuning has shown dyno gains with running the E55 airbox set up on a C55. expect around 5-15hp gain +/-.
Pulleys: AMS motorsports makes a light weight crank pulley that is much lighter than stock resulting in less rotational mass. It has been show to gain HP in the low and mid range some have even seen peak HP gains as well.
EVOsport offers an underdrive pulley kit for the C55 that is good for about 11hp (so ive heard)
Superchargers: RENNtech, Kleenamm and HPS make superchargers for the C55. Make sure you do your homework when choosing a supercharger thats right for your car. Dont be afraid to ask around or search the boards. VRPtuning along with EVOsport who are sponsors of this forum can help you out with your forced induction needs. I hear you can get a low boost Kleemann charger for around 9k Renntech is around 15K ouch! Some members will even tell you the old Kleemann blower is better than the new one.
Exhaust: Most C55 guys start out with chopping of the resonator and it is known on the board as being called a Res-delete, this is IMO the best $50-$100 you will spend on your car, the sound is amazing. Also You can chop out the secondary cats and pick up some HP along with a very mean sound. Custom dual exhaust in an other option for the C55 any exhaust shop can do this. Be aware the car will sound loud (in a good way) VRPtuning if you are in their area can also do this for you. Supersprint makes mufflers for the C55 but they are very pricey. IMO the stock one sound very good with any variation of exhaust mods.
Air Filters: Most C55 owners like to run K&N or Green filters there are a few other options out there but k&N or Green is the way to go.
Wheels: Not realy going to get into this much. Choosing the right wheel with correct offset and backspacing is like rocket science to me. In most cases Lighter is better, Forged wheels are stronger than cast wheels. Make sure the wheels you buy for your C55 are "hubcentric." Some members will tell you wheel spacers are not the way to go. IMO if you can avoid them just avoid them. However there are members that use then with no problems at all. If you want wheel spacers go with a good name when buying them and dont skimp. H&R and EiBach is a good place to start. Some high end wheels need spacers so it is what it is.
There are many wheel companies on this forum that can help you get the right wheel for your C55.
20 inch wheels will look stupid on a C55 they will kill your performance and rub like hell. stick with 18's or 19's. Its your best bet not to go wider than 9.5 inches in the rear.
LSD(limited slip Differential) for around $1400 some say its a must have for the racer Kleemann, Qauife make some good LSD's from what i hear talk to
James@ACGSD (sponsor) he can get you one. The LSD will help put all your power in the C55 to the ground rather than just spin it away.
Brakes: I wish i could remember their names but there are some sponsors on this forum that can line you up with a set of brakes that will make your head hit the windshield when stopping. Also Bembo make a good set for C55's Im sure some of the sponsors of this site can line you up with brembo brakes if thats what you want. I think RENNtech, Stoptech, and Eurotek all have apps for the C55. just make sure your wheels will clear the calipers as they are in most cases larger than stock.
Also look into some ceramic brake pads I got some at AutoZone and love them.
Suspension: RENNtech, H&R, Bilstien, Eibach all have suspension Compoents for the C55. from Springs to full coil over systems. EVOsports website www.evosport.com has some suspension stuff for the C55.
Tires: If your C55 came stock with Contisports just get rid of them I had them and hated them. Almost anything is an upgrade over the Contisports.
I hope this helps the New C55 owners that are on this board. Happy modding and be aware its a vicious uncureable sickness this modding game. Remember mixing different parts will yield gains. some better than others
I think someone should do this for the New C32 owners that are joining the site
Hooley, the difference between Kleemann headers and the others is that they have a down pipe that deletes your primary cats. If not you can purchase there high flow cats. The header itself is a direct bolt-on the only thing is the welding of the down pipe to the rest of the exhaust. On the set-up I had it had the primarys deleted then it went to an x-pipe, from there to high flow cats and then custom duals to the rear. There are clips on YouTube with the car on the Dyno incase someone wants to here it. Is posted here as c55asleep? Dyno run.
Fantastic list, and a perfect resource for our new members. This is just what I have on my car, minus a couple cosmetic goodies.
The NA items listed will add about 60 hp to 75 hp total to your C55 and improve handling. The 2005/6 SLK CLK 55 AMG rear brakes and 18" Turbine AMG wheels (ala SL 55) also fit and look great on the C55.
The Evosport cf front lip provides a noticeable amount of down force on the front end and improves handling.
I got my ECU tuning from EuroTech and posted Dyno's for all of my mods.
Don't forget phenolic spacers to limit losses from excessive heat, Denso IK 16 irridium plugs and the Optima Red top battery that you will most likely need if you install the evosport underdrive pulley kit and have bi-xenon's.
I think its important that new owners of the C55, SLK55 or CLK55 with the N/A 5.4L M113 motor Not only read the whole thread as other members will add to the list of mods you can do. I stress by no means is this list complete as there are losts of other companies, sponsors and what not that can get your car where you want it to be.
When i said in the brake section of the post about Brembo, I think just looking at Brembo for brakes would be doing your self a slight disservice as there are lots of sponsors on the forum that can get you well set up with massive amounts of stopping power.
My base line on a Dyno Dynamics dyno was 291whp and 301wtq with only bolt on im at 342whp and 357wtq. those are big gains for not going F/I and just sticking to bolt-onsIs there a Phenolic spacer for this car and if so who makes one?
Maybe we can get the powers that be to sticky this so us C55 owners can add to it and make it easy to newbies to find it.
I'm debating if I should go "k&n" again. I mean, it was dyno proved on a c320 for like a 1hp gain lol. but does the k&ns/green really "flow" better? I feel like those filters are for **** and giggles.
You make the call I guess.. I'm happy with my green filters.. Hope they don't fail like ole ones...
