Wheel Shimmy
Old Oct 25, 2008 | 06:10 PM
abhatti55's Avatar
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
Wheel Shimmy
When coming to a stop from 30 mph or above the steering wheel gives a solid vibration/shimmy. My first guess is the brake rotors. Car has 64,000 miles do you think the control arms could be bad? Car is smooth on the highway only does it when braking.
Old Oct 25, 2008 | 06:42 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Probably warped rotors.
Old Oct 25, 2008 | 06:50 PM
jturkel's Avatar
02 C32 AMG
+1....had this problem. replaced my rotors, problem solved.
Old Oct 25, 2008 | 07:14 PM
abhatti55's Avatar
Thanks for the quick reply. I'll order a set Monday, just found out I had a broke motor mount as well.
Old Oct 25, 2008 | 07:20 PM
jturkel's Avatar
02 C32 AMG
is your car covered by warranty? i think those require a fair amount of labor to do....i thankfully had my motor and tranny mounts replaced under warranty.
Old Oct 25, 2008 | 09:39 PM
abhatti55's Avatar
unfortunately not, guess it will be a diy job
Old Oct 26, 2008 | 03:32 AM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Old Oct 26, 2008 | 03:34 AM
saer1one's Avatar
you should also check your control arm bushings since your going to be down there already. i had to change my upper control arm bushings a month ago at 37k miles on my 2002 c32. i was suprised to see that in a car with only 40k miles but hey....
Old Oct 26, 2008 | 09:57 PM
abhatti55's Avatar
When I bought the car, the front right rim was bent pretty bad and had to be replaced. I noticed some hairline cracks on the bushing for that side. I hate to buy new rotors and that not be the problem or vice versa.
Also, how bad is this motor mount job going to be? Is it a DIY weekend job?
Old Oct 26, 2008 | 10:28 PM
Mikegpr03's Avatar
C63
Listen go to a really good machine and I mean really good shop and they can turn your rotors. There is a min thickness on them make sure they only take off the min.
Good luck
Old Oct 26, 2008 | 11:19 PM
ScottW911's Avatar
Good luck
It's my understanding that you can't turn drilled rotors. Just replace them. I bought drilled and slotted rotors for all 4 corners for $249. No worries.
Old Oct 26, 2008 | 11:20 PM
abhatti55's Avatar
That is a deal where did you find them at the price?
Old Oct 27, 2008 | 12:21 AM
ScottW911's Avatar
Check the "newbie" sticky at the top of this forum. There is a link to the L2 rotors. The vendor has gone a bit hinky and raised prices since. They are still good rotors at a good price, if you can get them. I found L2 on eBay, but they turned out to be a local SoCal company for me.
