LET intake installation
After that I put on the metal pipe section, but I was wondering how it's supposed to stay put. It has a metal bar sticking out. Is the metal bar supposed to just sit on top of the engine's airbox mount? It would be better if it was clipped on so it wouldn't come loose.
Then put the tubes to the 55 splitter as you can angle them to get them to fit in right.
Then, remove the metal u shaped clips that hook on to the mushroom looking black rubber pieces that are on the engine (from the stock), and slide them over the tabs on the let intake. The metal clips are what is used to keep the intake on the engine.
I forgot to transfer the clips over.
