Elec. Stabil. Prog. ESP Visit Workshop
Old Nov 17, 2008 | 04:00 PM
Chazz's Avatar
C32 ///AMG
I have researched this common problem but I have yet to find a definitive answer on why I get it. Over the last year it has happened to me once or twice but now it's occurring nearly every time I hit WOT with the ESP turned OFF. It never happens when it's left ON.
Sometimes after I limp to a stop and turn off the car and restart it, the error goes away but then the Supercharger won't engage. Just the same as when my IC pump was going out maybe 6 months ago. I replaced the IC pump and haven't had any problems until just this last week.
Could the IC pump be causing this error? Maybe it's going out again?
When I first started having "sluggish" performance earlier in the year it was completely random. I could never make it happen when I wanted it to. (Murphy's Law). Now, it's only happening after coming off of a WOT. It engages, I take off like a bat out of Hell but when I let off the pedal I get the message and the car goes into "limp mode".
Whatcha think?
Old Nov 17, 2008 | 06:05 PM
timberman's Avatar
silver 2002 c32 amg
could be I/C pump again
could also be throttle actuator or even battery/alternator going bad
by the sounds of it the problem is getting worse so it's probably best to get the codes read before you end up stranded possibly miles from home
Old Nov 17, 2008 | 10:22 PM
c32used's Avatar
LET C32 2002
+1
Old Nov 17, 2008 | 11:19 PM
kindafast's Avatar
W210 E55 & W204 C63
I have the same problem!
But it goes away after i restart the car so how can the dealership read the codes?
Old Nov 17, 2008 | 11:30 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Could be air trapped in the lines after the IC replacement?
I seem to remember someone had a problem with this before.
Old Nov 17, 2008 | 11:32 PM
e240TT's Avatar
E 240
the code will still be stored as stored codes as long as u don't pull the battery or erase it.
Old Nov 17, 2008 | 11:41 PM
Chazz's Avatar
C32 ///AMG
It happened again tonight and along with the visit workshop light came the check engine light. That's a new one. It stayed on for a couple of short trips to the store and then after about the third start the check engine light went away.
I also popped the hood and checked it out while it was running and found that I had a slight wobble in the tension pulley. I'll be taking it to my mechanic in a couple days.
Old Nov 18, 2008 | 12:09 AM
kindafast's Avatar
W210 E55 & W204 C63
hey chazz, does the car wobble when you start it sometimes?
Old Nov 18, 2008 | 12:42 AM
Chazz's Avatar
C32 ///AMG
Yep. Over the last week or so I have noticed a very, very slight vibration while driving. I haven't really noticed it so much at idle. I originally thought it was some sort of tire vibration but after finding the wobble tonight, I'm almost positive that's what's causing the vibration.
Old Nov 18, 2008 | 07:57 PM
evilsaint's Avatar
'02 C32, '10 135i M-Sport, '10 E63, '17 GLE63S
I had almost this same problem (with ESP on or off, but not in Dyno mode, almost always at WOT, usually when it tried to shift), and the dealer actually fixed it by replacing a part of the wiring harness. It was a TSB related to C55s, actually, but they fixed it under my extended warranty. I've randomly gotten the message a few times while driving the car really hard since, but it's never gone into limp-home mode again ( :: knock on wood :: ). Let me run and see if I can find the part # for what they replaced.
Old Nov 18, 2008 | 08:08 PM
evilsaint's Avatar
https://mbworld.org/forums/c32-amg-c...e-problem.html
Check that out when you get a chance. I didn't have nearly as many symptoms as that guy, but I brought it into the dealer and tried to get me to pay (a non-covered expense) of $1100 or so to replace the Throttle Valve Actuator. The actual quote from the Service Summary is "Performed short test, test codes P202E, DTB 30.201/61B (<--- the TSB for it?), Installed electronic throttle cable adapter harness."
The P# for it is 113 150 00 28, from a private, licensed MBoUSA dealer, so it may be different than in other databases - I don't know MB P# formats or anything.
Let me know if there's anything other info that I can get you that might help. By the way, could you take a picture of which pulley it is that's wobbling? I have one that looks a bit funky that I've only noticed since I ended up with a F'd up idle a few days ago, and I'm wondering if it's the same thing...
Old Nov 18, 2008 | 10:53 PM
Chazz's Avatar
C32 ///AMG
Thanks for the help evilsaint. However I can't get that link to work?
After looking at it this afternoon, I noticed that the Crankshaft pulley was creating more of the wobble than the tension pulley. For some reason in the video below it doesn't look quite as bad as it does in person. I have no idea why the camera picked up the sound like that. It doesn't sound anything like it does in the video.
http://s65.photobucket.com/albums/h2...Crankshaft.flv
I'm taking it to the shop on Thursday. I checked the belt and there were a couple of spots that had some small cracks it. Time for a new belt also.
Old Nov 19, 2008 | 02:50 AM
evilsaint's Avatar
Fixed the link for ya. And yeah, I have no idea about that wobble, but it definitely doesn't look too healthy :-x
Old Nov 30, 2008 | 01:37 AM
2002 C32, 2012 S550
Hey Chazz,
What did your mechanic say?
This just happened to me on Friday night. WOT with ESP off and it went into limp mode. I turned the car off and it ran normal again. Then I tried WOT again and the SC turned off and the engine light came on.
It's normal again now, but I'm gonna have my mechanic try to read the codes on Monday. It's fine now, but I'm afraid to go WOT again.
Thanks in advance.
Old May 18, 2009 | 03:00 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
any update on this? i'm having the same problem now.
Old May 18, 2009 | 10:41 AM
2002 C32, 2012 S550
I think the problem for me was my Throttle body actuator. I did not want to buy a new one, so I had it rebuilt by BBA Remanufacturing. Unfortunately the problem came back after a couple months so my mechanic wants to send the Throttle body back to BBA as they have a lifetime warranty on their work. However, it also means another 2 weeks downtime to send it out and get it back. It was $400 to have it rebuilt by BBA.
All my CEL's pointed to the Throttle body actuator.
Good luck as I'm pretty frustrated by now.
Old May 18, 2009 | 11:09 AM
TemjinX2's Avatar
thanks for the update..i've searched other posts and looks like the problem was solved by replacing the engine harness. i think i'll try that route first.
Old May 18, 2009 | 11:31 AM
2002 C32, 2012 S550
Yeah I'll let you know how mine goes.
BTW, isn't the engine harness very expensive as well?
Old May 18, 2009 | 03:17 PM
evilsaint's Avatar
The TBA is what my Stealership wanted to replace first when I was having this issue (not covered by my extended warranty, ~$1200...), because they said the loose wiring causing this was only on a TSB for the C55 engines. I paid out of pocket for them to replace just part of the wiring harness (~$240 inc. labor, the wiring that goes to the TBA, I would assume - the service order is worded very vaguely) and the problem hasn't come back since.
I've had that periodic SRS light/code come on since then, but that's apparently something completely different. Never had the car go into limp home mode since (knock on wood x 3) though
Old May 18, 2009 | 03:20 PM
evilsaint's Avatar
The other thing that I forgot to mention - I couldn't pin down the timing on this, but my IC pump %100 kicked the bucket very shortly after I had this problem "fixed" by replacing that part of the wiring harness. Literally, I went onto a frontage road not even five minutes away from the dealership to test out their work, and all of a sudden *BAM*, S/C started cutting out for the first time...
Old May 18, 2009 | 07:44 PM
TemjinX2's Avatar
i would say the two problems arent related. since my intercooler pump is running fine. i only started having this problem once i sold my code3 pulley and went back to stock.
do you have the part number for the harness? the dealership wanted $500 for it but wouldnt give me the part number.
Old May 18, 2009 | 08:10 PM
evilsaint's Avatar
I'll look around for it - It's in one of a million boxes laying around right now and I have a nasty cut on my finger that's still coagulating >_>
Old May 18, 2009 | 09:37 PM
TemjinX2's Avatar
yeah whenever you can. i'm pretty sure i can find it for half price on line. just like the dealership quoted me $1500 for the throttle actuator when its online for 750.
Old May 20, 2009 | 06:06 PM
evilsaint's Avatar
Temjin - I doubt this is the right part #, but here goes - 113 150 00 28
That's what listed on the repair paperwork. The actual description was "... test codes P202E, [I}DTB 30.201/61B[/I] (that's the C55 TSB, I think), installed electronic throttle cable adapter harness."
The price for the part on the repair order was only $76, so it was probably a shunt off of another separate portion of the engine wiring harness.
Sorry for not being able to be more clear about this - I'm just going with what I have. I do remember somebody else with this issue zip-tying some part of his wiring harness (some part with a plastic connector that wasn't staying totally closed) and having that solve his problem, though I wouldn't have the first idea where to look for something like that.
Either way, all I know is that I had a feeling that it was NOT the throttle body actuator, so did the service writer actually, so we went the cheap route first even though the TSB/DTB was for C55s and voila - it worked =)
Old May 21, 2009 | 03:38 PM
TemjinX2's Avatar
thanks for the part number. i'll start with that first. anyone know a place to get it online other then parts.com. The website always lags out for me when i try to buy the part.
