Wheel Offsets. Lets post some setups to see what fits or can fit.
Old Nov 18, 2008 | 10:32 AM
MI SO FST's Avatar
C55
I'm interested to see what size wheels can fit our W203 AMG's. Lets see your set up's I am going to use "sdsilverm3" car as an example since I dont yet have any wheels to show.
Size
F: 19X8.5 +32 235/35/19 with 5mm space which would be a +27 offets (I think)
R: 19X9.5 +32 265/30/19
Not sure of any fenders are rolled or not
Old Nov 18, 2008 | 10:53 AM
c32used's Avatar
LET C32 2002
Good thread! Lets post people...I have stock setup.
Old Nov 18, 2008 | 11:26 AM
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
this may be a stupid question but i gota ask: are spacers bad for the car? do they take anything away from the drive? i have always wondered this but never got a ans.
Old Nov 18, 2008 | 11:39 AM
MI SO FST's Avatar
C55
not really as long as you do it right. Get the right ones for the car with the hubcentric centers and what not. Also make sure you have long enough studs/lug bolts for it.
Old Nov 18, 2008 | 11:49 AM
MRAMG1's Avatar
S600, GL450, GLC 43
You are ALWAYS better off with the CORRECT offset wheel, period. Spacers are just another route of failure my friends, with MANY potential headaches. With that being said, the above advice is good, ESPICALLY remembering about LONGER wheel studs/bolts. But NOTHING beats the correct offset, and with SO many wheels available there really is NO GOOD reason not to order the correct wheels to begin with, IMHO.
See yeah
Old Nov 18, 2008 | 01:38 PM
thx for the help.
Old Nov 18, 2008 | 04:32 PM
coin's Avatar
'06 CLK500
Lorinser LM6 19x8.5 19x9.5
Some pictures from my old C320:
Front: 225/35/19 19x8.5 ET38 w/ 7mm spacer
Rear: 255/30/19 19x9.5 ET38 NO spacer
On a side note, they are for sale and I'd give local pick-up better pricing
Old Nov 18, 2008 | 04:39 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
https://mbworld.org/forums/c-class-w...want-know.html
Old Nov 18, 2008 | 05:00 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
I'm running 18x8 front ET35, 18x9 rear ET 32 BBS RG-R's with 12mm hubcentric spacers in the front. I really don't have any decrease in ride comfort, but I definitely have better brake pedal feel and steering response since they weigh around 9lbs less at each corner, and are pretty much the lightest non-mag wheels I could find. Although you barely can fit a credit card between the wheel and the front caliper.
My friend runs like 15mm spacers on his NSX with either his BBS or Volk wheels and tracks the crap out of it, so there isn't too much to worry about.
Old Nov 18, 2008 | 05:06 PM
MRAMG1's Avatar
S600, GL450, GLC 43
I guess you have never seen one crack? Or how about shatter at the track?
The frist of course only leads to a bad vibration, the latter, well you get the point. I NEVER said it could NOT be done. I simply stated that why in the world would you NOT buy the correct rim in the first place
Oh well, to each his own, but if I wore to spend $4000+ I certianly would want the right rim that oh I don't know FITS MY CAR
See yeah, and enjoy
Old Nov 18, 2008 | 05:29 PM
DarkXerox's Avatar
Well these were the wheels that I wanted and this was the only way to make them fit since BBS doesn't make the exact offset for this wheel. And I paid 2k with tires so I couldn't pass up that deal. Besides I don't track it so I'm not worried. I figure that since the same wheels/spacers can handle that kind of stress on the track, mine should be fine. If I were to track the car, I probably would be different wheels for that with non-street tires, e.g. painted stockers like other people do around here.
Old Nov 18, 2008 | 08:16 PM
Calspeed's Avatar
... are always a good time.
Great topic... as long as it stays on topic! Thats why there are "PM's"
I will be fitting some 19's in a few days. Working with 32F and 35R. Unrolled fenders and dropped with HR's and stock shock pads. Tire selection not established. 255's or 265's.
As for spacers, it takes a little work to get the right rim. I thought about spacers for a minute. Then I thought about track days and decided to go with exact fitments.
Good luck!
Miguel
Old Nov 18, 2008 | 08:32 PM
coin's Avatar
'06 CLK500
Good luck!
Miguel
Let me know if you need some 255/30/19 tires.
A friend of mine has an unused set for sale.
Old Nov 18, 2008 | 09:14 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i'm running a destaggered setup. 19x8.5 all around with 235/35/19 tires. offset 42mm
Running 15mm hubcentrice spacers so et is 27 in the front
Running 12mm hubcentric spacers in the rear so et of 30 in the rear.
No vibrations, same as stock.
Old Nov 18, 2008 | 09:54 PM
DarkXerox's Avatar
Oh, I thought you had C63 rims?
Old Nov 18, 2008 | 10:27 PM
TemjinX2's Avatar
i have the replica's...they dont make oem in 19''. They were originalyl designed for the w204. I bought them when they first came now..now they have w203 offsets.
i also wanted destaggered so i can route them since i drive almost 20k a yr.
Old Nov 26, 2008 | 03:47 AM
sdsilverm3's Avatar
See yeah
BBS sells wheel specific spacers that are high quality, TUV approved, and come with the appropriate bolts. I ran them for close to 2.5 years with no issues whatsoever.
How many wheel companies in the US can claim TUV approved even with the correct offsets? I can count them on one hand. BBS being one of them, even with spacers.
Old Nov 26, 2008 | 06:04 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
BBS, Brabus, Carlsson, Lorinser all do.
anyway...mine from newest to old.
BBS RE
18x8 ET35 (10mm PFS from BBS with bolts) = ET25
18x9 ET38 (took the 5mm PFS off due to excessive rubbing on rear tires)
235/40/18
265/35/18 (yes the size is the reason for rubbing)
DCR Laguna Seca
19x8.5 ET30 235/35/19
19x9.5 ET35 265/30/19
Carlsson 1/16 BE
19x8.5 ET28 235/35/19
19x10 ET35 265/30/19
HRE 448R
19x8.5 235/35/19
19x9.5 265/30/19 (don't remember the offset sorry)
Axis Phin
19x8.5 ET33 (8mm custom spacer) = ET25 (tire stick out past the fender like a mother f-er. the stupidest move i've made with wheels) 235/35/19
19x9.5 ET38 265/30/19
Lorinser LM-6 replicas
18x8.5 ET35 225/40/18
18x9.5 ET38 255/35/18
and stock
Old Nov 29, 2008 | 02:07 AM
Calspeed's Avatar
19x8.5(F) 235/40x19 32 Offset
19x9.5(R) 265/35x19 35 Offset
H&R Springs with stock spring pads. OEM shocks.
Lots of rubbing when driving in the City. Especially with passengers.
Required some trimming of the rear bumper/trim metal bracket to reduce rubbing. (10-15 minutes with a Dremel MotoTool)
Still have a slight rubbing only when drifting the car. Otherwise there isnt any rubbing anymore. Will lift the car again for another session of trimming. Or maybe I will have to finally get a set of Koni's.
Miguel
Attached Thumbnails Wheel Offsets.  Lets post some setups to see what fits or can fit.-img_6308.jpg   Wheel Offsets.  Lets post some setups to see what fits or can fit.-img_6295.jpg
Old Dec 13, 2008 | 07:06 PM
MI SO FST's Avatar
C55
Originally Posted by FrankW
Carlsson 1/16 BE
I really like the Carlsson wheels.
Old Dec 14, 2008 | 12:57 PM
Montsu's Avatar
E55 -03 Kleemann K4
Me2, that was the best wheel setup you posted....
Old Dec 14, 2008 | 03:49 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
235/40/18
Have you tried rolling the fenders to clear your 265 x 35s?
You have a good aesthetic selection of shoes
I've contemplated on switching to 18s but, honestly, 19s really look much cooler, I've gotten so many compliments out there on the road.
Old Dec 14, 2008 | 05:17 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by 60n5pt1
235/40/18
the fenders were already rolled.
Old Jan 17, 2009 | 08:31 PM
MI SO FST's Avatar
C55
anyone have pics of 19's on stock suspension?
Old Jan 17, 2009 | 08:45 PM
advans's Avatar
C55 ///AMG, 535xi
running at 35mm front 37mm rear, 235/35/19 and 265/30/19, I tried running a 275/35/19 dropped on my C320 coupe, it rubbed.
