new electrical problem
2002 C32 amg, 1998 328i
I stomped the throttle to clean out the cobwebs today, and a red light popped up with "BATTERY/ALTERNATOR" visit workshop. When I turned off the car it reset. I took it for another drive and it did it again. Now it also shows a 3rd fault in yellow and it has the battery symbol again saying something about undervoltage, consumer defective. I put a meter on the terminals and Im only reading 11.63 volts. As I remember most cars should read 14-15 volts while running to recharge the battery and to run all electrical devices?
Any responses from the service world would be great. Sounds like a dead alternator but it seemed wierd with the timing. I had recently had problems with dead batteries cause of seat modules and replaced the battery. Would that cause my alternator to go bad? 1 month later
I stomped the throttle to clean out the cobwebs today, and a red light popped up with "BATTERY/ALTERNATOR" visit workshop. When I turned off the car it reset. I took it for another drive and it did it again. Now it also shows a 3rd fault in yellow and it has the battery symbol again saying something about consumer defective. I put a meter on the terminals and Im only reading 11.63 volts. As I remember most cars should read 14-15 volts while running to recharge the battery and to run all electrical devices?
And unfortunately from what I was told, C32's have a very specific alternator that isn't used on other Mercedes, so it might be hard to find a remanufactured one.
But then I found this on eBay:
http://cgi.ebay.com/ebaymotors/NEW-C...1V#ht_1249wt_0
Good luck!
probably alternator
Brand new battery. Im concened because Im only reading 11.63 which likely is only the battery's voltage. Im sure the running voltage is to be 14.4 volts. I was hoping getting on it maybe the belt was slipping and not spinning the alternator and I needed some reset.
02 C32, G60 Corrado
It sounds like your alternator is going bad. I had the same issue this summer it was the alternator. I ended up changing it myself, it was a ***** but very satisfying since they quoted me around $2000 at the dealer. Independent mechanic should do it for you for a lot less if you don't want to mess with it. Check out my thread and other threads on bad alternator, they are very helpful. I got my alternator from the website I mentioned for around $280 shipped, however you do have to swap out the pulley. Which my mechanic did for free. Also, you should stop driving the car it will eventually leave you stranded as the battery drians and all sorts of message appear and eventually the car would shot off. Good Luck.
Learned the hard way and had to finish 2 mile walk to work at 32 degrees.
Same exactly problem- happened today!!!
A bit different symptoms: at idle voltage 14 anything over 1500 rpm- dropping below 12 volts.
Imediately took it to trusted shop - confirmed alternator failure.
Quoted repair cost:
hold on to your seats............
Labor: $120.00
Parts- brand new alternator......
$160 - $40 core charge.
Total $240.00
Brand New Part might get edited after I will pick it up tomorrow
That is what I was told. Purchesed in the past few alternators and starters from them - all of them were as discribed-always new- non rebuilt, never used.
Will update tomorrow early afternoon.
Regrds
Jack
must be the cold !!!
They just must be getting older and the cold is finishing them off. Im stuck in Des Moines Iowa, so no local parts place had one so I have to wait 2 days
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
2002 S500
CLS, SLK, ETC
It could be 1 of 4 problem listed below.
1. ****ty battery
2. Seat Module (common in C32s)
3. Voltage regulator ( I had this replaced and problem was gone)
4. Alternator... (quite expensive..
Good luck
1. ****ty battery
Good luck
