seat module
Old Dec 13, 2008 | 06:42 PM
RedBull's Avatar
CLK550
seat module
Well it was my turn for the seat module failure. I went out to the garage to get something out of the car and it was as dead as can be. I'll probably do the $20 fix that was posted up on here until I can find replacement modules, and just unplugged the modules for both seats for right now. I'm going to miss the heated seat.....
Old Dec 13, 2008 | 08:25 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
all you have to unplug is the first connector closest to the door. The one closest to the center of the car is the heater and it can be left plugged in.
Old Dec 13, 2008 | 10:00 PM
RedBull's Avatar
CLK550
Cool, thanks Jake.
Old Dec 14, 2008 | 02:58 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
yeah those modules are junk.
Old Dec 14, 2008 | 11:20 AM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
If you end up looking for a new one Brad, let me know.
Old Dec 14, 2008 | 01:54 PM
neihouma's Avatar
02 C32 AMG sold!
Unplug fuse #27 or #33, they are both 30amps so that way you'll have
the seat you like w/out looking like you're driving a lowrider
Not the best pick but you get the idea
And what's this $20 fix I just read???
Old Dec 15, 2008 | 02:06 PM
warnhammarc32uk's Avatar
Hey,
Have you got one for sale have you? What does removing those fuses do? Is that just a way of de-activating without dangling wires?
Jon
Old Dec 15, 2008 | 06:42 PM
RedBull's Avatar
CLK550
I unplugged just the one connector closest to the door, and the car has been fine since. I had the car sitting outside all morning in the wonderful sub-zero winds and it still started up just fine. Thank goodness I can still use the seat warmer.
Old Dec 16, 2008 | 04:43 PM
gaz's Avatar
gaz
C
Freaky behavior from mine today! Everytime I tried to move the seat there was a relay click and rev counter drop to zero, speedo drop to zero, all warning lights on dash on bright. 20 mins later, all back to normal. Reckon I might be having a flat battery one of these mornings.....
Old Dec 16, 2008 | 05:34 PM
Fifth Ring's Avatar
C32 AMG
A weak battery makes these cars do wacky things. In addition to a transmission problem, I was able to open my sunroom but not close it!
PS: I'm on my second attempted seat module replacement (first one was dead) from some shop in Frederick MD. If it doesn't work this time, I will be looking at the hardwire mod.
Old Dec 16, 2008 | 05:40 PM
1qikctr's Avatar
Merc power
I wish Mercedes do a full recall on the seat module failure. This issue drives all Benz owners NUTZ.
Old Dec 21, 2008 | 03:48 AM
TemjinX2's Avatar
just click on my sig. you can just take a relay and get a 12v source as the trigger and turn the seat module off and on with the 12v source.
For example you can use the cig lighter as the trigger so it'll only turn on when you put the car in the second position and turn off when you take out your key.
Old Dec 21, 2008 | 08:57 AM
RedBull's Avatar
CLK550
Got the new seat module, just haven't had time to install it until today.......and it's 5 below zero right now. My car is in the garage, but it still gets cold in there.
Old Dec 21, 2008 | 10:59 AM
RedBull's Avatar
CLK550
Just finished installing the new seat module. It's nice having a fully functional seat & steering wheel again. Thanks again Bryan.
Old Dec 21, 2008 | 11:47 AM
No problem Brad.... anytime.
Old Dec 21, 2008 | 03:06 PM
neihouma's Avatar
02 C32 AMG sold!
Damn I have signatures turned off. Thank you kindly
Old Dec 22, 2008 | 01:30 PM
Donmun's Avatar
2002 S500
Do you have the wiring diagram for the seats? the relay fix is ingenious, i cant believe i did not think of it. thanks
Old Dec 22, 2008 | 03:38 PM
Fifth Ring's Avatar
C32 AMG
YGM.
I've had TWO different seat modules (not new ones) sent to me by a MB salvage shop, and neither one worked at all. It seems kind of strange. They looked like the original unit, and all the plugs were the same. But in both cases, the module was dead. My original module still works -- it just kills the battery. These modules did nothing.
Old Dec 22, 2008 | 06:10 PM
RedBull's Avatar
CLK550
The car sat out in the brutal cold all day while I was at work, and started up just fine after 10+ hours in -15 wind chill. No more worries.
Old Dec 22, 2008 | 07:41 PM
TemjinX2's Avatar
unfortunately i dont, i had to figure it out the hard way. someone suggested you can just use a switch to turn it on and off.
Seems like a easier solution for a lot people. I added the info to the seat module thread.
Old Dec 22, 2008 | 07:42 PM
TemjinX2's Avatar
Originally Posted by Fifth Ring
YGM.
yeah i had the same experience with the ones i bought on ebay too. They worked for 6months then had the same problem...all modules junk except for the new revision ones.
Old Jan 12, 2015 | 06:26 PM
Dknowz's Avatar
2006 C55 AMG
TemjinX2 can I just pull the fuse instead of disconnecting the seat control module?
Old Jan 14, 2015 | 07:25 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
You can try and see if it works...
Fuses are:
2, 21, 27 for driver's seat;
1, 22, 38 for passenger's seat.
1 and 2 are in the rear SAM in trunk.
2x and 38 are in the driver's side fuse box.
(If the fuse positions are the same across all W203's that is)
