brake fluid light
04' C32 AMG & 90' TT 300ZX
brake fluid light
My brake fluid light came on on Saturday (yesterday) I only stayed lit for like 3 seconds. I barely got to read it but I know it was a circular icon and and it brake fluid and some other stuff i think. What does this mean? Am I low on brake fluid, or does that mean that I drove so and so miles since last flush and I should get some new brake fluid in there?
Thanks.
Thanks.
Super Moderator
Doesn’t normally consume fluid, although its level in the reservoir will drop slightly as the pads wear.
It’s probably best to have the entire brake system inspected straight away.
Super Moderator
If your fluid was low enough to have the light come on for any reason and for any length of time it should be flushed, period. Besides the fact that the brake pads are likely well worn from new, and nearly in need of replacement in this case anyways.
That aside brake fluid also becomes acidic (just like coolant) and needs to be removed and flush for the exact same reasons as above. The potential to damage vital brake components is enormous and shouldn't be played around with. In fact brake fluid SHOULD be flushed at each and every brake job (whether it is just resurfacing rotors, or a complete overhaul). I mean flushed, not just simply bled, there is a major difference.
Thanks. I'll flush the fluid when I replace the pads and resurface my rotors. I just thought that there was a Mercedes reasoning behind it. I'm not used to being told by the car whats wrong and what needs to be changed and when.
Super Moderator
Yes, “consumed” was a poorly chosen word to convey that the volume of brake fluid contained within the system remains relatively constant, barring any external leakage. I regret its use and misinterpretation. The brake fluid level warning lamp will only illuminate when the fluid level in the fluid reservoir drops precipitously, typically due to the additional caliper piston displacement from extensive brake pad friction material wear, or from a potentially catastrophic breach in the hydraulic system.
Mercedes-Benz insists upon biannual brake fluid replacement for several well-founded reasons. Owing to the fact it’s hygroscopic, the boiling point of the fluid continually degrades over time. Anyone who has experienced brake fade from boiling fluid during spirited driving understands the importance of regular brake maintenance. As you correctly state, the fluid also absorbs detrimental chemicals from the internal mechanical components that comprise the system. Regular fluid replenishment is far less costly than replacing the master cylinder, ABS/ASR unit, or calipers.
I do, however, respectfully take exception to that portion of your post which intimates top-tier brake fluid refiners knowingly and/or intentionally include water in their formulations. Their MSDSs typically indicate minuscule levels, if any. In nearly every instance, performance-oriented technicians will dispense brake fluid only from a sealed container in order to minimize its deleterious exposure to moisture-laden ambient air. Some of us renew the fluid before each road course event in an effort to mitigate the fluid’s hygroscopic properties and help ensure proper brake system operation under severe operating conditions. While that may be a bit much for the typical Mercedes-Benz owner, proper brake system maintenance is never something with which to be trifled, IMHO.
You obviously have a background which includes automotive engineering.
Pleased you’ve chosen to become a contributing member of our forum.
Reference:
MB’s perspective…https://www.mbwholesaleparts.com/Sta...lushSept04.pdf
Brake fluid performance characteristics...http://www.stoptech.com/tech_info/wp...fluid_1a.shtml
Reference:
Not to discount your advice, but brake fluid is actually 'consumed' Dot3 and Dot4 fluids are partly water, and it gets hot and the water portion evaporates, leading to degradation of internal brake components. I.E. Brake lines, fittings, flex hoses, and most importantly the ABS pump.
