Needswings SuperCooler
Old Feb 27, 2009 | 08:21 AM
ImportLabSRT's Avatar
2006 E55 2005 Crossfire SRT-6
Originally Posted by SilverBulletAMG
What do you mean by seperate the cooling system?
The engine cooling system and heat exchanger both source coolant from the stock overflow bottle. To separate the systems, you purchase a coolant over flow bottle and remove the line from the bottom of the stock tank that goes to the radiator. With the system separated, I can beat on the car for hours and the coolant in the stock tank is cool to the touch.
http://www.crossfireforum.org/forum/...ad.php?t=27178
Old Feb 27, 2009 | 08:28 AM
SilverBulletAMG's Avatar
C32 AMG
Ahhh ok, I knew about that mod but I still thought it was all linked and the added overflow was just to add "volume" to the system. Guess I need to take a closer look at that setup. Thanks ImportLabSRT!
Old Feb 27, 2009 | 08:34 AM
No problem, thats what Im here for
