Transmission flush / coolant flush
Old Mar 18, 2009 | 02:00 AM
C32_Underdog's Avatar
C32
Hi all,
I have found alot of info on the forums and need to change my 2001 valeo radiator asap My transmission makes buzzing noises at low rpm, and the 1500 rpm jerk is constant.
Even though the TSB explains Glycol contamination testing, I could not find a TSB on what I need to do. I am going to do a transmission oil change and radiator change/coolant flush at the same time.
I hear you cannot flush the torque converter, so anyone have a TSB on exactly how to fix the problem explained in the Glycol TSB?
