6mm spacers?
6mm spacers?
Anyone know a good place to pick up a set of hub centric 6mm 5x112 spacers? I need them to clear the kw's with Dunlop zstars that are 9.6"!
Thanks,
Sean
Thanks,
Sean
1 Post
744 C36 AMG,040 C43 AMG, CLK55 208, CLS55 IWC, CLK500 Rocketbunny widebody
6mm dont exist. So either stack 2 3mm (wont be hubcentric) or get a 5mm. Other than that go custom. I think lorinser might have 6mm not sure...
2002 c32 AMG 2012 c250 Coupe
Hmm. I guess I could stack up 3mm hub centri H&R spacers from that site, but already have a shop making them for monday for less than that. Thanks for the offer though Cannonball. I may still hit you up on that diffuser. Thanks guys, I'll keep you updated. I guess this is what happens when you're 235 section width is about a 245-255 so I'm told by the shop!
'06 C55 AMG
35 offset 5mm spacer bfg kdw tires 225/40/18 the new tire /wheel combo is 19x8.5 toyo t1r's 225/30/19. hopefully the shop isn't charging you much. I could probably do them set of four for like 100.
Ah 225s. Thats the rub. When I had 225s stock I didn't need spacers with 31mm offset. The spacers will be under or at 100. I also have the new special 14mm ball seat bolts for them. I can't wait to get the damn car back it's been about 5 months in the shop now! Many clk63bs parts added hehe. Don't ask about the duration out ugh...
I used to go to this guy to make some custom spacers. He does an excellent job if anyone needs custom spacers and uses ALCOA 6061-T6 billet aluminum for his stuffs (hubcentric with a lip as well)
http://www.wheeladapter.com/
