Check engine light question
2003 C32 AMG
Hey all. I recently picked up a 2003 C32 AMG with just over 51k miles. The car has the cats deleted. For the first day or so I had no light, but today the "Check Engine" light came on. I did the service reset deal to see if that would clear the light, but it did not. My question is how mild to severe can a "Check Engine" light be on these cars? Thanks!
Former Vendor of MBWorld
C55,SL55,C63
Welcome to the forum, Stick around for a few minuets the C32 guys will help you out. Just ad some more detail on what cats are deleted, primary or secondary cats, Your car had 4 cats total. Are you sure it was not just a resonator delete? Lots of C32 guys just do that and leave the cats in place.
2003 C32 AMG
2003 C32 AMG
2003 C32 AMG
2003 C32 AMG
Here's some of the codes pulled today: P2027 B17/8, P207E, P200B, and the last one is hard to tell it looks like P2003. The weird thing is the car seems to run perfect and pull great when throttled. Other times it seems like the car is in "limp" mode and the acceleration seems greatly reduced. Any thoughts, ideas or opinions? Thanks!
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
The P2027 and the "limp" mode are related. Most likely your IC pump needs to be replaced. Can your OBD friend take a measurement of your IAT? If your IAT is high like 180+ while driving, the ECU will not engage the SC and will briefly kill the fuel delivery.
The other two codes sound like they are cats related, but I don't know. Others have deleted secondary cats without any issues. I'm about to delete them myself next week when I install the new Supersprint exhaust.
2003 C32 AMG
Most everybody now days uses a Johnson CM30 pump. You can get one from here http://autoperformanceengineering.com/html/jabsco.html or from here http://www.letmotorsports.com/produc...2&category=all. If you are a DIY person, you can do it in an hour +. There are instructions somewhere on the forum. As far as the shop doing it, it depends on the rates. 1.5 hours is more than reasonable IMHO.
2003 C32 AMG
If it isn't the I/C pump are there any other "known" problems in the C32's that would cause the aforementioned problems?
It's hard to tell since the car is used and you don't know the full history but I would says that based on the P2027 code and your description, it is the IC pump or the IAT sensor itself. Others may have more ideas for you.
2003 C32 AMG
Well it seems the pump is getting power, but isn't flowing so i'll be getting one of the those pumps listed above. The thing is the car keeps throwing a catalytic code. Are there replacement O2 sensors to keep the car from throwing codes?
O2 sensors are available for anywhere from $120-$160. What is your mileage?
The OEM O2 sensors are recommended to be replaced every 100K miles.
2003 C32 AMG
It's hard to tell if it is the cats or the O2 sensors. I would say it is O2 sensors, but don't spend any money based on this "remote" diagnosis.
Depending on who you purchased the car from, the seller could well have had the same codes and cleared them prior to selling it to you. It's unfortunate, but there are dishonest people like that out there. Sometimes the error codes reappear immediately; however, sometimes the error codes take days (or longer) to reappear.
You scanned via OBDII and found P2027, P207E, P200B, and P2003.
Even though your car only has 51K miles, these codes may not necessarily be related to each other and you may have several issues to contend with.
P2027:
As alluded to by the earlier responses by the guys, this code indicates your implausible IATs and that could be due to a faulty sensor or (more likely) a dysfunctional charge air cooling (IC) pump. Easy fix.
P207E and P200B:
These codes suggest that the efficiency of your left and right primary catalytic converters is insufficient.
You said that you smelled fuel and you are not positive as to which converters are present / absent. Look at the schematic below for the catalytic converters and determine which ones have been removed (if any). If your 1o catalytic converters are absent, then it is not surprising that you have P207E / P200B error codes.
P2003:
Can be related to P0410. This can be a malfunction of the secondary air injection system which is obviously a component of the emissions system. Several components may be suspect in this case; however a common problem is the faulty air pump and / or the air pump relay. If it isn't these, there could be problems with the O2 sensors, misfiring, or the EGR system.
![](http://i265.photobucket.com/albums/ii232/boohooramblers/Catalyticconverters.jpg)
2003 C32 AMG
So.... You recently acquired your car and you coincidentally get a check engine light soon after your purchase?
P2027:
P207E and P200B:
P2003:
P2027:
P207E and P200B:
P2003:
The oxygen sensors are upstream and downstream of the primary cats so it doesn't make any sense to remove the primaries. Are the oxygen sensors still in place?
Removal of the secondary cats is a relatively popular modification amongst C32 owners with significant modifications - it is claimed that a few whp can be picked up upon their removal.
The only thing I can think of off hand is that the previous owner had some custom long-tube header setup that required removing the primary cats due to down-pipes. Perhaps they had racing cats instead? Hmmmm - definitely a little odd.
In any case, if your primary cats are indeed missing and you don't plan on installing replacements, you may be able to reposition the oxygen sensors so that they are upstream and downstream of the secondary cats. Just a suggestion. Otherwise, you are going to continue to get those error codes.
Another possible solution may be a tune. Kleemann has a header setup for the M113K that involves removal of the primary cats. They have a tune that apparently takes care of the error codes. Perhaps a similar addition to an M112K tune is possible?
Either way, if the car was lowered significantly, it should have been aligned.
2003 porsche 996 turbo
go to apeusa.com for the cm30 johnson pump. 145$ shipped. when i replaced mine i used siome rubber tubing froma bike tire and wrapped the pump. then i drilled 1 hole and tapped it were the original pump mounts and used the cm30 mount in the same location. i also drilled out the electrical plug from the old unit and soldered and heat shrinked the pos. and neg wires to it with a small 20k capacitor so as to not have to cut any factory wires. replaced old clamps with new ones and refill with a 50/50 mix of distilled water and m/b antifreeze. total time 2 hrs
be aware the new pump flows much more than the old. consider a code 3 or let heat exchanger so the flow wont back up at the intercooler inlet.
2003 C32 AMG
Are you sure? I'm trying to think of reasons why somebody would remove the primary cats (rather than the secondary cats).
I was told the car has H&R springs. Yes, the excessive internal wear is what gave it away. Looks like I may need some struts as well. Any suggestions?
2003 C32 AMG
