supercharger electro magnetic
Old May 3, 2009 | 07:52 AM
janne's Avatar
mercedes c32t amg
Unhappy supercharger electro magnetic
hello my electro magnetic in sc have been broken something is wrong whith it can i change this out or must i change the sc for this if it is brroken
Old May 3, 2009 | 09:39 AM
boohooramblers's Avatar
Not an AMG :(
The simple answer is that the clutch can be changed without installing a new supercharger.
We may be able to help you more if you give us more details regarding what is wrong with your supercharger clutch.
(i.e. did the bearing fail?)
Old May 3, 2009 | 10:52 AM
janne's Avatar
mercedes c32t amg
hello yes the bearing fail
i had some realy noise from the supercharger just in idle speed coming from the clutch sound donk donk
Old May 3, 2009 | 11:04 AM
janne's Avatar
mercedes c32t amg
i have taking the cluth out and the bearing is bad realy bad the mb tech said i have to change the clutch have any body any pics of the sc in al parts
Old May 3, 2009 | 03:22 PM
320 dreamer's Avatar
2003 porsche 996 turbo
i beleive code 3 has the bearing you need to change. no need to replace the clutch
Old May 3, 2009 | 05:20 PM
Jani Anttila's Avatar
C32 T-modell
Your nick tells me that you might be from Finland?
If you are, call Kentso Oy, they have the bearings on stock. It is quite hard part to find. Part numbers can be found on the forum.
