Some recent problems...
First, I was getting on the freeway when my car all of the sudden lost all power, seemed as if the supercharger wasnt even working. So I do a quick test and sure enough it said the problem was the IC Pump. I have my JohnsonCM30 on its way...
And yet another problem... I get a red warning light a few days later while I'm driving and it says Alternator/Battery...So I check my battery and everything is tight and it is a relatively new battery as well...
So I do another quick test and it says that it is the voltage regulator...I take my car to the stealership to have a new one put on, but I get a call about an hour ago from them saying that I need a new alternator and it is going to cost $1250
and on top of that I owe them $120 for the labor of them putting in the voltage regulator..All in all I am just going to pay the $120 to get my car back but I need a place to get a new alternator for cheaper than $1250. This sh** is adding up with new tires and a car payment coming up as well
Does anyone know if it would be a hard DIY, or know of a place that can do it for cheaper in SoCal? Also should I get a better one, or just replace it with a stock one?
Search this forum for the alternator threads. I know I contributed to a couple of threads that ended up with some great contributions from members that found some great DIY solutions. Otherwise, I went to a local indy shop, near the Irvine Auto Center, that charged me 1/3 what MBLN wanted.
https://mbworld.org/forums/3188668-post5.html
and here:
https://mbworld.org/forums/c32-amg-c55-amg-w203/258769-how-long-does-c32-alternator-usually-last.html
They have a lifetime warranty...
I had a 300e before I bought my C55 and when the Alternator went bad I checked PB on a high output alt from a S55? to transplant and it was around $200
I learned about this from when I had a VW GLI that had a Bosch 110 amp alternator.
They had a plastic cup around the rear bearing that would disintegrate around every 30k miles.
After replacing the alt. once I bought one from PB and after that every 30k or so when it went bad I would call the local PB and make sure they had one in stock then pull the bad one and take it back for warranty replacement.
Heh, I drove that car for 200k miles and the lifetime warranty saved a bunch of money.
They should discount you about $250 if you let them keep the broken alternator, because they send them back to Deutschland, repair and resell. And it sounds like $1250 is for the install and parts, about what I paid.
here's the link where you can buy it...provided by boobramblers
http://www.bimmerspecialist.com/part...154-02-02%2088
I just checked and I see the regulator does come seperate.
003-154-17-06 @ $134.00
the cost of the MB alt is $677 w/exchange
http://epc.startekinfo.com/epc/
Been there, done that.
