Fading Display MFD?
"A zebra stripe pad is a box-shaped rubber block. It has alternating insulating and conductive segments. Those are on a fine pitch.
The zebra stripe is compressed between the circuit board pads and the LCD pads. Those have a coarse pitch.
The result is the zebra stripe creates multiple electrical connections between the LCD and the PCB.
The problem is crud and oxidation. Those screw-up the connections.
The solution is to disassemble, clean and reassemble. Both the LCD and PCB are rectangular panels, with the zebra stripe compressed between.
Good luck."
Thought this might be helpful for those of us DIYers who are out of warranty and who have the "fading MFD" curse (especially when hot).
Thanks for the info, Wingless.
Good luck."
https://mbworld.org/forums/c-class-w203/299250-w203-multi-function-display-fading-class-action-suit.html
But mine never becomes illegible. Do you guys get to that point?
