Heat Wrap Anyone?
To do the insulation wrap you have to remove the supercharger. The IC does not break because of the stronger pump. The pressure in the IC is higher on the Air-Side than on the liquid side. I prefer a separated system, because of lower fluid temps and because of the advantage to run the intercooler system with less Glycol. ( better Heat-Transfer of the IC-fluid)
also, im guessing the CM90 flows MORE than the CM30 is that correct? any reason why you chose that much more flow? i know some guys over on the srt6 forum are using that meziere (spelling?) pump like eleventeen and are happy with that too.
also, if you are running the CM90 pump FULL time, arent you concerned about the life of the pump? i'd imagine running a pump all the time would dramatically shorten its life, and that with your amazing cooling setup, you probably wouldnt even need to run it all the time?
At the track-I could get me Evo X up to 240 (prior to switching to pure water)-the C55 hit 215 on a sunny 80 deg day last week up there.
I assume you are running 100% water and wetter? I dont/wouldnt think you have to worry about freezing like I do
actually, my setup is straight 50/50 MB coolant distilled water mix. i have thought about changing that mixture to more like 70/30 or 60/40 in favor of water but havent gotten around to it yet. i think running pure water would be bad though.
While running pure water may help for a little, there are too many problems with doing that. its not too cold here to do that, but too hot. water boils at 212 which means that i would have some major issues if i ran pure water. if the coolant mixture boils it obviously will cause problems. Adding in the coolant to the water changes the colligative properties of the coolant solution by decreasing its vapor pressure, thus raising the boiling point of that mixture to like 225 or something (love chemistry, my fav subject in college lol). so its completely necessary to use at least a 30 or 40% mixture containing coolant.
As far as water wetter, no i'm not running that either. someone actually told me it doesnt do anything though i want to try it anyway. (lol actually just did a search and found this:http://www.thetruthaboutcars.com/red...%C2%AE-review/)
after hearing and reading about water wetter, i just dont trust it enough to run straight water with it. i'd definitley consider adding it to a mixture though
Removing the SC and do the Heat-Wrap is 2-3 hours, if you have practical experience.
if the s/c removal and heat wrap take 2-3 hrs, i may do that within the month. thanks again!
also, and this is for anyone, does ANYONE think there is any more room in the engine bay somewhere for a second heat exchanger (stock C32 one)?.......i know this might sound crazy, but would a bottom mount h/e do much? i know some cars actually have bottom mount air/air ICs on their F/I setups
