- Need help fellow 32 owners -
Old Jul 7, 2009 | 10:54 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by 1qikctr
You have problems 2? yeah same here.. i dont drive the 32 as often anymore... dude i'm thinking about getting another car
but not worth it to sell the car. 7yr old it may be. I still enjoy driving it.
Old Jul 7, 2009 | 11:49 PM
1qikctr's Avatar
Merc power
Def not worth selling it! yeah, i was acknowledge by the shop that they did not found the probable cause of no power source to fuel pump since they manually power the fuel pump to test start the car now the car fires up like a champ again with np They did changed out my old relays - spark plugs.
Much appreciated to all the help gotta love the C32/C55/203 group
Old Jul 8, 2009 | 09:47 PM
1qikctr's Avatar
Merc power
Crap car does not start again. Mutr fawkr.
Old Jul 9, 2009 | 01:22 AM
1qikctr's Avatar
Merc power
Drove the car home from the shop around 5pm, after coming home, the car wont start. I left it for over 5hours and now it fires up again, wtf??? took it for a spin Supercharger is completely shut off, my johnson c30 pump is not on eighter, i checked fuse in the rear tunk but all fuse are in working condition. Is there someother fuse i should be looking in to ?
Old Jul 9, 2009 | 02:17 AM
ML500K's Avatar
C32 '02
Have your shop do a fuel pressure test under the bonnet, it could tell u if ur fuel pump is bad. 50-60psi is the regular pressure. I had to replace mine when the pressure fell to 30psi. ( the car wasn't accelerating and stuttering when pushing on the pedal and takes forever to start )
~cheers
Old Jul 9, 2009 | 02:23 AM
1qikctr's Avatar
Merc power
~cheers
I will mention that to my shop tomorrow. god dammmm it... was ur Supercharger on during the fuel pressure issue ?
good thing i have my new c219 drive around
Old Jul 9, 2009 | 10:46 AM
  #32
ML500K's Avatar
C32 '02
had the "issue" pop out of me when i was stopping at a red light, when it turned green i applied a light touch to the gas, but it started to "stutter" and it would accelerate very very slowly;(not more than 10mph and could go much higher) i pressed further down the pedal and it was still the same, so at that point i knew something was up. Basically i couldn't even drive the car, so the SC probably wasn't really engaging. I took the car in for a check up and the first thing the guys did was to hook up a pressure gauge to fuel rail , and it was below 30psi...after cranking. Swap out the old pump for a new one, and I also replaced the fuel filter. Everything has been fine since then. Hope ur issue is as simple as mine.
Old Jul 9, 2009 | 03:54 PM
  #33
1qikctr's Avatar
Merc power
The car is at Mercedes sf, 1st problem SC relay replaced. Now, they need to find out as why there is no power to the fuel pump. Will update all the results.
Thank u ML500k, see your from taipei, I'll be back to taipei soon myself, in fact my lil sis is going bck taipei tonite lol. Xie le ! for the fuel pressure info.
Old Jul 9, 2009 | 04:26 PM
  #34
tokyo0one's Avatar
'03 C32
My car had the exact same symptoms as your car. Drove it up to campus yesterday and then it just wouldn't start 5 hours later. Waiting on the shop to diagnose the problem. Sad day for the both of us...
Old Jul 9, 2009 | 10:46 PM
  #35
1qikctr's Avatar
Merc power
I'm waiting for my car to come back tomorrow. As for now, there is nothing i can do since my car is in the shop. I'm sooo mad at my 32 since i barely drive it and it gives me problem, i was hatting my merc for over few hours.. but after driving my c219 out i feel a lot better dammm benz u hate them u love them can't fight'em join them.
Old Jul 10, 2009 | 01:32 AM
  #36
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Seems like relays are a prob for this car.... I had the IC pump, computer replaced under warranty... thank god...then had the same problem after a year and found out it was a bad relay which I replaced myself.
Old Jul 10, 2009 | 01:56 AM
  #37
1qikctr's Avatar
Merc power
My car just a bad connection near the rear fuel pump. I will get to the button of this problem by 2m,i will report back with results.
Old Jul 10, 2009 | 04:49 AM
  #38
ML500K's Avatar
C32 '02
No problem ~ Seems like mercs just have their idiosyncrasies, once we figure out how they work, all is good...just like women
Old Jul 10, 2009 | 06:13 AM
  #39
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i'm hating my 32 atm as well.
i'm loving my C350 tho except it's telling me i got 25day to next service.
Old Jul 10, 2009 | 04:02 PM
  #40
1qikctr's Avatar
Merc power
thanks again.
i like the c219, but since is a 550, it sucks a lot of gas the way i'm driving it. I just got the car back from merc shop, they dont know where the problem is at, no CEL no stored codes, charged me "0" i know the sales director!!! i took my rear seats apart, took the fuel pump cover off, sand down the female connection where it connects. Everything seems to be back in working condition ( so far ). I'm tired don't want to drive the 203 anymore Lovin the c219/550 smooth no trouble. I want a used 07-08 M5 drove my friends M5, man this 4 door can get down and dirty.
Old Jul 12, 2009 | 01:14 AM
  #41
tokyo0one's Avatar
'03 C32
The shop told me that the car has a blown wire but i cant remember exactly what wire it is. I'll let you guys know as soon as i can get an update. Too bad the car will by out of commission until at least next Friday!!! Seriously thinking about getting another car...
Old Jul 12, 2009 | 02:07 AM
  #42
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
thanks again.
do it. if you can get use to the 15mpg from the M5.
after changing out the ignition wire my mpg came back up to 23-24 on the highway vs 20-21 on the 32.
Old Jul 12, 2009 | 01:48 PM
  #43
1qikctr's Avatar
Merc power
Let us know the results when u get the car back .
Frank, the m5 i drove was bone stock, i was reading about 10 mile to the gallon thats a lot of gas to shout out if i drive it daily.
Old Jul 13, 2009 | 06:12 PM
  #44
tokyo0one's Avatar
'03 C32
So did you find out what's wrong with your car?!!
Old Jul 13, 2009 | 06:58 PM
  #45
1qikctr's Avatar
Merc power
Yeah, got the car back took off the rear seats, pulled the fuel pump cover, connectors off, cleaned and polished the contact area with 1000 grip sand paper. All seems to work fine now, at least for the moment. There were no power to the fuel pump, i took advise from mr CLKCLK's pm, problem seems to be solved at the moment. I don't drive the 32 too often..... so wont know till i take it for a long drive - road trip !!?!
Old Jul 13, 2009 | 10:15 PM
  #46
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
that's about right.
15mpg I said is for HWY.
Old Jul 13, 2009 | 10:32 PM
  #47
1qikctr's Avatar
Merc power
^^ i'm jobless at the moment. still dreaming about new cars.
Old Jul 28, 2009 | 12:22 AM
  #48
tokyo0one's Avatar
'03 C32
Just got the car back. So apparently a relay burnt out causing the fuel pumps to fail. The thing is the car now runs like a snail. It feels exactly like when my IC pump failed last year.
Do you guys think the relay burning out could cause the IC pump to fail??
Old Jul 28, 2009 | 04:32 PM
  #49
W203Ramos's Avatar
you're right happened to me twice since I owned the car
Old Jul 28, 2009 | 05:36 PM
  #50
1qikctr's Avatar
Merc power
The problem is your shop guy put the relay back in to the wrong slot. Just move the relay up one slot. If not, move the relay down a slot. I ran in to that problem few weeks ago
