- Need help fellow 32 owners -
Old Jul 5, 2009 | 09:38 PM
1qikctr's Avatar
Merc power
- Need help fellow 32 owners car wont start with no CEL -
Hope everyone had a great 4th July weekend. So, try to take the 32 out today for a drive. Car wont start up crank after crank, changed the Crank position already 5000 miles or less. Did few search on the forum but did not get any vital information as what is the cost, any help would be great guys.
Old Jul 5, 2009 | 09:41 PM
DarkXerox's Avatar
07 E550, 02 C32, 91 300E
Did you have this problem before? I think I remember reading something but couldn't remember if it was you.
But I think I also remember hearing that the throttle position sensor could be a problem on our cars so that might not be bad to look at.
Old Jul 5, 2009 | 09:44 PM
jturkel's Avatar
02 C32 AMG
not sure if this is the same problem, but check this link, maybe it will help. i just had a loose fuse
https://mbworld.org/forums/c32-amg-c...ont-start.html
Old Jul 5, 2009 | 09:56 PM
1qikctr's Avatar
Merc power
Thanks folks, i changed the CPS crank position sensor out less than 5k miles ago. since there is no check engine light - codes, i dont know where to start -diagnosed the problem.
Old Jul 6, 2009 | 12:10 AM
1qikctr's Avatar
Merc power
Damm need to find CLKCLK... he had the problem found on search, but no answer to what cost it.
Old Jul 6, 2009 | 12:40 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
maybe you should give a more detailed description? does it crank? just no ignition? do all your electrics work? or they low on power?
Old Jul 6, 2009 | 12:48 AM
1qikctr's Avatar
Merc power
Car turns over, cranks, all electrics works in order. Car have full juice, but just wont start up. I did some search on the forum found no answer. I also checked my rear fuse box #4 fuel pump ( its in working order). Also checked started it sounds fine (starter solenoid clicks). Alternator works... where else should be looking?
Old Jul 6, 2009 | 12:58 AM
TemjinX2's Avatar
whats the mileage on your car"? maybe spark plugs or fuel pump.
Old Jul 6, 2009 | 01:04 AM
1qikctr's Avatar
Merc power
76kish, spark plug humm i have to look in to it. umm as for fuel pump i need to find out what needs to be replace. sigh... headache from the 32 again.
Old Jul 6, 2009 | 01:07 AM
TemjinX2's Avatar
maybe check your plugs and remove your rear seats and see if you can hear the fuel pump running when you crank it. The car's cranking and you power. Sounds like its either not getting fuel or there's no spark.
I would shoot Splinter a PM too..he's the c32 guru.
Old Jul 6, 2009 | 01:21 AM
1qikctr's Avatar
Merc power
yeah, i'll check my plugs 1st and fuel pump issue first. Thanks Tem for the suggestions. sigh merc problems
Old Jul 6, 2009 | 01:43 AM
TemjinX2's Avatar
good luck... let us know how it goes.
Old Jul 6, 2009 | 05:54 PM
1qikctr's Avatar
Merc power
waiting for the towed truck to come, 32 is going to the hospital.
Old Jul 6, 2009 | 06:21 PM
320 dreamer's Avatar
2003 porsche 996 turbo
3 things needed for a car to run. 1 fuel 2 air 3 spark. troubleshoot each one to locate the problem
Old Jul 6, 2009 | 06:23 PM
1qikctr's Avatar
Merc power
yeah: i'm lazy at the moment, no time, no patients. Now the car is on it's way to the shop, will write more details later about the problem.
Old Jul 6, 2009 | 08:01 PM
1qikctr's Avatar
Merc power
Just got a vital piece of info from CLKCLK, ignition fuse 46-48 might be loose. Crossing my finger nothing serious with the 32.
Old Jul 6, 2009 | 09:10 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
ignition fuse maybe or fuel pump.
hope you get it fixed soon bryan. and did i spell your name right? LOL or am I way off. **** i'm bad with names.
Old Jul 6, 2009 | 09:16 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I dunno, maybe in nuts, but this sounds a lot like a dead battery...
When I called MB roadside cuz of this same issue a few years ago, they asked me to turn on my stereo and/or my lights. They both came on while I could hear my car cranking attempting to start up. They told me my battery was dead - they came out, swapped out my battery and the car started up like nothing had happened. They had to clear the esp/abs issues and resync my windows...
Test out the battery? Good luck!
Old Jul 6, 2009 | 10:53 PM
mkonei's Avatar
05 C55
crank but no fire would be fuel or spark. weak pump, or no power to the pump at all is a good place to look.
Old Jul 6, 2009 | 11:11 PM
1qikctr's Avatar
Merc power
yeah franky it's spell with the Y, my 32 is in the shop. Just got phone call all fuse are in working order.
As for the battery, its in 100% working order. I just have to wait till the shop call me tomorrow and see whats wrong with the damm 32 good thing i have other cars to drive #*$^#%* our old w203s
Old Jul 6, 2009 | 11:17 PM
1qikctr's Avatar
Merc power
Again, much appreciated for everyone's input and thoughts.
Old Jul 6, 2009 | 11:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
lol...my barely drive the 32 anymore. parked for 6 day waiting for the ignition wires to come so i can fix the misfire.
Old Jul 7, 2009 | 12:04 AM
1qikctr's Avatar
Merc power
You have problems 2? yeah same here.. i dont drive the 32 as often anymore... dude i'm thinking about getting another car
Old Jul 7, 2009 | 09:03 PM
1qikctr's Avatar
Merc power
Latest update, i was told fuel pump have no power source, after replacing the relay for the fuel pump and spark plugs,all things are back in working condition. Phew, appreciated too all
Old Jul 7, 2009 | 09:31 PM
TemjinX2's Avatar
good to hear it was a cheap relay and nothing major.
