Resonator Delete, what pipe size etc?
Old Jul 28, 2009 | 04:12 PM
  #51
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
gotdabenz,
I did not use them. I decided to get a few mods done as one package at ttmotorsports in farmingdale long island. you could look them up http://www.ttmotorsports.com/careers.htm however, i think your best bet is to purchase the pipe @ http://www.verociousmotorsports.com first then go to any muffler shop that could do the work for you. GL!!!
Old Jul 28, 2009 | 04:29 PM
  #52
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
I have heard of ttm. They look expensive. Did he quote you a price for the ecu tune?
Old Aug 8, 2009 | 12:36 AM
  #53
W203Ramos's Avatar
expensive, yup. this is because they wanted several mods on a package basis. so I decided that I will do the mods myself. I think for my purpose, simple mods will be doable. did you finaly get your exhaust done?
Old Aug 19, 2009 | 06:20 AM
  #54
murks's Avatar
C32
Hello Guys. Having posted my original post I did not get email updates so it was great to read the thread.
So, you all had a laugh at the $260 price tag I have been quoted to do this in the UK. Tt's Crazy aeh!
Heres my situation. I used to be an aluminum fabricator for Yachts. I have used an arc welder (stick) to do mild steel and a Mig to do Aluminum alot.
I have some car ramps, and can get enough clearance to get under there to to it myself. I am wondering if anyone can help me with the following info:
1) Looks like I will get some 304 grade stainless 3" pipe. £30
2) I will hire an arc welder for the weekend (£30 with sticks included)
3) Put the car up on ramps and cut the resonator off and weld in the new pipe, job done for £60 ($100 USD) and a bit of elbow grease.
Heres my questions:
1) Will the Arc (stick) welder be suitable for this job, and does anyone know what stick size to use for the weld?
2) Is 3" 304 grade stainless the best pipe to use. What wall size is the best?
3) Can the bolts near the front cats be undone easily so the exhaust can be dropped from the car? What size are these bolts and do I need a joint gasket or compound when putting it back together?
4) Do you recommend undoing this join and tak-ing the new pipe in place on the vehicle, and then taking the exhaust off to do the full welds?
5) Any other info would be valuable from someone who has done or seen this process.
I really think that this will make a great difference, hence my investment to try to do. It's crazy the prices for custom work over here and I think I can achieve this from doing it myself.
From what I have seen the sound is noticeable and impressive.
Thank you for any info.
Old Aug 19, 2009 | 10:16 AM
  #55
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
Just had mine done yesterday...
Here's the vid:
Now - I must point out, the actually underbelly picture used is not mine - it's one I gave to the guy who worked on my car.
We used 2 1/2" stainless pipe to replace the cats & 3" pipe for the resonator.
Work done by Buckhead Imports (Jason Cummins) in Atlanta, GA. GREAT GUY!
http://www.youtube.com/watch?v=5UajEGhBLG0
Old Aug 19, 2009 | 10:34 AM
  #56
murks's Avatar
C32
Great Vid thanks!
Nice tone. For what the car can do, MB should have released it with a bit more sporty tone to begin with.
Old Aug 20, 2009 | 01:33 PM
  #57
sammyd's Avatar
2005 C55 AMG
For anyone else on the fence about doing this - I just went to the local muffler shop, showed the owner a picture from this thread, and said the going rate for this should be about $60. He said no problem. He also said he could tack weld the pipe and let me drive the car around a bit to make sure I liked the sound (on the freeway too). So I think that's a good way to go.
This is happening on Monday, I'll let you know the results!
Old Aug 21, 2009 | 05:56 AM
  #58
murks's Avatar
C32
Can anyone help with this info?
Originally Posted by murks
Heres my questions:
Old Sep 13, 2009 | 05:47 AM
  #59
Phil_W's Avatar
C32 AMG
Hi,
does anyone cut off the original resonator and weld in it some pipe?
Here in germany its a little bit strange if you modify the exhaust. So it should looks like original.
Old Sep 13, 2009 | 08:25 AM
  #60
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Originally Posted by Phil_W
Hi,
Yes, you got it. Cut of the original resonator and weld in a stainless steel pipe.
Old Sep 13, 2009 | 08:42 AM
  #61
Phil_W's Avatar
C32 AMG
Yes, same what i think.
But is there anyone who ever tried this?
Maybe with pictures?
Old Sep 13, 2009 | 09:30 AM
  #62
Lenin's Avatar
Phil,
read this thread from the beginning. There are pictures and info on the second page.
Old Sep 13, 2009 | 09:40 AM
  #63
Phil_W's Avatar
C32 AMG
Yes, but without opened-resonator. Only changes with some pipe
My question is, if anyone has some photo of opened resonator.
Sorry if i described it a bit strange in the post before.
Old Sep 13, 2009 | 02:55 PM
  #64
AMG Keggers's Avatar
C32 AMG
Hello, new here to the forums, so Hello everyone!
I Got a C32 here in the UK.
Has anyone done a resonator delete and can let me know what pipe size I would need to purchase, and what material the standard C32 Exhaust is made of?
I have good mig and arc welding skills, but need to know the pipe size and material of the exhaust so I can hire the right welder to put the replacement pipe in. It's very expensive to do custom exhaust work over here at a shop, and not as easy to get this mod done as it seems in the USA so I am going to have a go myself. (I have been quoted $300 USD to do this job, so can hire a welder for $40 and do it myself.)
Any tips to drop the exhaust system lower (get top of pipes welded) or what welder type, pipe type, and rough amp settings would really help thanks.
Thanks alot for any info,
Regards, Murks
For what it would cost to rent the welder it would be cheaper to get it done, had mine done at powerflow and it was £40, btw its 3 inch pipe, you wont be disappointed only in the fuel consumtion as you become addicted to the sound lol
