Johnson CM30 - 12v vs. 24v
C32 AMG, Trans Am, Lincoln Navigator, E36 325i
Hey fellas,
Well the stock intercooler pump is on the way out. Upon searching for replacements the CM30 keeps showing up as a solid performer. Here's the question...
Where can I find one of these bad boys? Eurocharged has them listed in stock on one site and out of stock on another.
Also, is APEUSA.com a valid source? They actually have two options, a 12v and 24v to be specific. Not to mention they have them listed for far less than Eurocharged, no offense to EC/LET, just a fact for us consumers. Which one do I want, the 12v or 24v?
Link to APE...
http://www.apeusa.com/html/jabsco.html
Thanks in advance...
Albert Hernandez.
Link to APE...
Albert Hernandez.
2003 porsche 996 turbo
just remember the cm30 requires a few very simple mods to work. use the oem plug from the old pump and i wrapped mine in some rubber from a bicycle tube and used the cm30 braket to fit it. drilled and tapped 1 screw hole
Albert Hernandez.
what some guys have done is use pipe insulation and reuse the oem bracket. works very well the thickness of the pipe insulation takes up the space between the cm30 pump and the rubber insulator of the oem pump
