MB Camber Bolts - more negative?
Subscribe
Feb 18, 2003 | 06:53 PM
Can I use the MB camber bolts to go more negative in the camber? Or are they only used to bring the camber more positive due to lower springs.
Reply 0
Feb 18, 2003 | 07:01 PM
yes, the MB camber correction bolts will change the camber a fixed amount either + or -.
Reply 0
Feb 18, 2003 | 08:37 PM
Yes you can use them
Not sure of the part number but I had them on my car. I got about 1.2-1.3 degrees of negative camber with RENNtech springs.
Talk to the parts counter.
Reply 0
Feb 19, 2003 | 10:19 AM
Thanks guys - I will pick some up today.
Reply 0
Feb 19, 2003 | 01:11 PM
Negative Camber
Upon realigning my car after the spring installation my mechanic was able to get 1 degree of negative camber front and rear without any camber kit or bolts.
I'm not sure if that was the max he could get stock or not but 1 degree negative is way better for handling the the OEM specs.
Reply 0
Feb 19, 2003 | 01:25 PM
The MB Bolts don't do much for camber. We are working on our own camber solution for the car, as the C32 needs 2-2.5 degrees of negative camber in the front.
Reply 0
Feb 19, 2003 | 04:02 PM
Ben,
Any idea when you will have these available?
Reply 0
Subscribe
Currently Active Users (1)
