Will Stock 17" Wheels Clear a 332mm StopTech Rotor?
Old Sep 7, 2009 | 01:42 PM
AirFrcd's Avatar
03 c32
Talking Will Stock 17" Wheels Clear a 332mm StopTech Rotor?
As stated, will a stock front 17" wheel clear a 332mm StopTech front rotor?
Thanks for your replies.
Old Sep 7, 2009 | 04:01 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it should. the stock is 332mm.
Old Sep 7, 2009 | 04:12 PM
Fifth Ring's Avatar
C32 AMG
Leading to the obvious question ....
As to fitment, The place you're likely to have interference is the outside face of the caliper assembly. That's why you don't see as many "deep dish" wheels anymore. Multi-piston calipers need a lot of clearance on the outside of the rim.
But the AMG calipers are pretty big; and stoptech should be similar. Trial and error.
Old Sep 7, 2009 | 05:16 PM
320 dreamer's Avatar
2003 porsche 996 turbo
c32 front rotors are 345mm arent they? so the smaller rotors will fit but the question is why go smaller?
Old Sep 7, 2009 | 07:35 PM
1Lop2K5C's Avatar
C63
The stock 32/55 rotor is 13.6 which is 345mm
Old Sep 7, 2009 | 10:15 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
stand corrected. i thought it was 13" for some reason.
