C3 intake theory C32...
Old Sep 8, 2009 | 07:13 PM
benzluvr1's Avatar
02' C32, '08 M6, '10 750LI, '06 993 turbo, 96' S600 V12 Coupe
I am wondering if putting C3 intake on C32 would actually defeat cold intake purpose..Seems to me the heat rising from back of motor would be sucked in and mix with and heat incoming intake air therefore defeating the purpose for installing it, which is to make more power..Warmer intake air, less power...Sound plausible?
Old Sep 8, 2009 | 07:20 PM
02C32guy's Avatar
2005 E55
That is the theory that many subscribe to. There are a few people that still use them, but for the most part I think you'll find that people are thinking the same thing you are.
Old Sep 8, 2009 | 07:21 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
hot air or not, it's better than stock.
I'm still trying to find a way to adapt it to my SL55 intake.
Old Sep 8, 2009 | 07:23 PM
benzluvr1's Avatar
Maybe someone can come up with a little cowl induction scoop right there...That would be really cool..Kinda like the old SS Chevelle's..
Old Sep 8, 2009 | 07:25 PM
jturkel's Avatar
02 C32 AMG
hey bunzluvr
good thinking. Per Code3's website:
"After testing a tremendous amount of intake configurations, we finally hit a home run. On a stock car, we picked up 4-7rwhp/rwtq. Used in conjunction with our supercharger pulley, we picked up 13rwhp/13rwtq. These gains are across the entire rpm range. Not only do you get great throttle response, but you get that kick *** sound that will definitely turn heads. IAT testing has shown only a minimal 5-8° increase in temps at full boost. This is due to the fact that the stock intake is still receiving cool air from the front of the vehicle.
The intake piece pictured replaces the air diverter plate in the back of the stock y-pipe. Your intake will look completely stock. The intake cages are made from phenolic. You are also provided a foam filter custom made by UNI specifically for our application. This foam filter can be cleaned and reoiled anytime. You can also purchase additional filters separately. "
i used to have code3's intake and agree with the bolded statements.
i know for a fact that i picked up power when i first installed; it was no placebo effect.
I also know (and miss a lot, to be quite honest) that really really loud supercharger whine. now dont get me wrong.....i have a loud supercharger whine right now with my setup.....but with the code3 setup, it is much louder....almost sounds like you're running a kennebell.....cobra style :x
IATs.....yes, Brandon (owner of Code3) admits they go up a little bit. I have not personally datalogged this setup but it makes sense the IATs would go up a little bit.
benzluvr1's Avatar
Hey Gramma, any HP gain with that SL55 intake? I take it you have the full setup from front to back..
Old Sep 8, 2009 | 07:28 PM
jturkel's Avatar
02 C32 AMG
agreed....more airflow coming in, and taking off the weather stripping on top of the engine bay behind that helps increase the sound and improve air ventilation even more i think.
...as in trying to get the stock c32 splitter to fit up with the SL55 boxes and hoses? if you are able to figure this out, PLEASE do share.....i've made a thread or two about seeing how that could be duplicated. obviously, the code3 intake cannot be used with the SL55 splitter because it is a y splitter, vs a T and does not have that removeable back plate. Ideally, to make it work, we'd probably need to fab up a custom T-splitter larger than stock but with similar length extensions as the 55splitter to mate up with the 55 boxes
thought about it, but not sure how a scoop would look on the C class.....photoshop anyone?
Old Sep 8, 2009 | 08:15 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
OK, it's official. I am one cowl induction scoop on a C32 away for trading my car in for something less jackass-able.
Come on. These are Mercedes Benzes we drive, on Chevelles, Novas, Pintos, Imprezas, Civics or Dukes-of-Hazzard cars.
Old Sep 8, 2009 | 08:54 PM
W211 BEAST's Avatar
2006 E55 BEAST
I'm sorry, but you need to see this to know that it's gonna look like complete ****?!?!
Old Sep 8, 2009 | 08:58 PM
benzluvr1's Avatar
Where there's a will, there's a way, fellas...
Old Sep 8, 2009 | 09:13 PM
jturkel's Avatar
02 C32 AMG
lol i know....i didnt really entertain the idea further when i pictured what it would look like.....not to mention it isnt an old muscle car
Old Sep 8, 2009 | 09:31 PM
2002 C32, 2012 S550
I can't give you definitive numbers one versus the other, but I do feel like the SL55 intake is capable of more intake volume. It has a deeper roar then the Code3 intake, but I liked the way the Code3 intake was more responsive and had a slurping sound as well as the louder S/C whine. I think Josh can agree with me on all these points.
However, I am thinking that even though the OEM t-splitter is more restrictive, it is less so with the Code3 intake attached. So I'm going to try and find adapters to fit from the SL55 intake box to the OEM T-splitter with Code3 intake mod. Likewise, I believe "Newzchspy" is running a modified LET intake along with the code3 intake for great results.
I think it will work well.
Old Sep 8, 2009 | 09:49 PM
jturkel's Avatar
02 C32 AMG
agreed 100% in sound comparison and volume comparison. my only concern is that using the stock splitter might nullify the point of having the SL55 intake boxes because the stock c32 splitter might not be able to flow the extra air taken in by the 55 hoses/boxes. dynos could confirm any power gains or losses.
Old Sep 8, 2009 | 10:01 PM
2002 C32, 2012 S550
Yeah, I know what you mean, however, my theory is that while the OEM splitter is a bottleneck without the Code3, it may not be with it.
Having more boost requires more air and likewise with a blower, it essentially SUCKS more air through our intakes. I'm thinking that the added volume of the SL55 intake boxes will allow for more volume to be sucked in, and the Code3 intake will unblock the restriction at the t-splitter. So I'm hoping that there will still be a benefit of the larger intake boxes AND able to reap the benefits of a more responsive throttle and great sound as an added bene.
I dunno if that makes sense? All I know if that Newzchspy is running 12.7's with just a code3 pulley, and the combo LET/Code3 intake.
Old Sep 8, 2009 | 10:21 PM
jturkel's Avatar
02 C32 AMG
yah it makes sense. see if you could do a dyno comparison with your data logging thing (if it does that)......probably wouldnt see a difference on an actual dyno b/c you wouldnt be able to replicate the air flow
Yah Newzchspy ran a 12.7 with code3 pulley, that intake, and a tune at i believe 109 at 110. i think thats normal. i ran a 13.0 at 109 with code3 intake, pulley, and tune on streets on 91 octane and 2800 DA.
Old Sep 8, 2009 | 10:39 PM
moosejaw's Avatar
none
NewzChSpy is running 12.7?
something tells me his GF Stevie Nicks is the motivation.....
Old Sep 8, 2009 | 11:29 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
the code3 intake is sucking in hot air, but that hot air is also travelling a lot shorter distance to the throttle body, then the cold air coming from the front of the radiator to the throttle body. Considering its SC..it just needs much air as possible regardless if its cold or hot. But of course cold air is preferable.
I have the cod3 intake and i did notice a more off the line response over stock.
