no response from gas pedal...help please
any ideas as to what the problem might be would be greatly appreciated.
lastly, I did the reset for the gas pedal thing and the car ran well for about a day.
C32 AMG - in Pewter
Sounds like a Throttle Position Sensor problem.
I am experiencing the same thing. Last time I took it in they said that a connector to TPS was lose, and scrued it back in. But the problem is back and I am taking it in today.
thanks for your input. I am going to bring the car to the dealer this w/e. but just to be more detailed about the problem.....it happened again today so i kept on driving the car and i realized that when i step on the gas pedal I don't hear the intake (code 3 whine) and when floored the pedal it down shifts and all, just no supercharger whine and very little power.
I do hope it's just the TPS and nothing to do with the supercharger. will keep you guys updated.......by the way Z06 NICE
Silver 02 C32 & White 05 CLK500
Car has power untill you start to push it, then when your intake temps reach a certain point it pulls boost and you are driving a benz powered by hampsters. Plenty of threads around dicussing the problems and fixing it yourself. Easy part to change on your own.
I would tend to lean towards the intercooler pump from your description as well. Mine went out a little while back and the symptoms are very similar to what you describe.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I got a call from my SA today and they told me the Trottle Actuator needs to be replaced. I am going to talk to the SA about the posibility of it being the TPS. Just don't want to spend 15% of the cars' worth on some BS part.
Please let us know what they did on your car. The sh***y throttle response has been bugging me for about a year now. I really hope it is something cheap cause I just cant spend ANY more money than what I already spent on this car. If it is the TPS sensor, let us know where you ordered it from or if you ordered the entire gas pedal assembly.
so after driving the car for a while and the symptom appears....I did notice that the car does everything it's supposed to when accelerating. when i stomp on the pedal it downshifts starts to rev (slowly) just no supercharger. this will happen for about 30-60 sec the the car returns to normal and runs strong. I've read numerous posts and threads and I think my ic pump is dead.....can anyone tell me how to check the ic pump if it is working? thanks
so after driving the car for a while and the symptom appears....I did notice that the car does everything it's supposed to when accelerating. when i stomp on the pedal it downshifts starts to rev (slowly) just no supercharger. this will happen for about 30-60 sec the the car returns to normal and runs strong. I've read numerous posts and threads and I think my ic pump is dead.....can anyone tell me how to check the ic pump if it is working? thanks![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
The intercooler pump runs for about 5 seconds after you shut the car off. After driving the car (long enough for the pump to activate) listen for the humming by the right front tire after you turn off the engine. Recruit a friend to help you out if you want, but you can make it over there if you are quick. No humming=no pump. According to fellow MBworld posters the stock units are a frequent source of failure even if you had it replaced recently.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
hope this info helps you guys......getting a bit frustrated with the whole guessing thing
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
according to the service manager at mb....if it was a tps sensor you would see cel's if not most probably the i/c pump. he said that the years 03+ will cut off s/c if iat's are over 199 degrees...and istead of a cel you would only see elevated iat's when connected to diagnostic compu![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
hope this info helps you guys......getting a bit frustrated with the whole guessing thing![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
going with a CM30?
just call up jake or jerry at eurocharged. they'll answer it for you. i'm pretty sure its plug and play. i dont have it though so cant confirm this.
OK, this is my experience. I hope it helps, but maybe not. Either way, good Luck!
When my IC pump went out and I floored it, there was a big jerk and loss of power. It was pretty clear it was the IC pump from researching others having the same experience.
I have also rebuilt my Throttle Body Actuator in lieu in buying a new one. It has a lifetime guarantee and done by a longtime reputable company for $400 with a two week turnaround time.
The bad news is, I think I have experienced exactly what you are describing to some extent. When I had issues with my TPS, the car went into limp mode and threw a CEL. Most of the codes pointed to the TPS, which is why I had it rebuilt. I have also been driving on the freeway and every blue moon, the S/C will totally shut off, I'll have zero power and it will not go back to normal unless I restart the car. No CEL, no limp mode. It would happen every few months or so. I do have to say that since I had the TPS rebuilt, I haven't had it happen again....YET. If you decide you do want to get it rebuilt, I got it done by this company:
http://www.bba-reman.com/uk/index.aspx
I have also bought the REV application for my iPhone and can now monitor IAT's, timing, intake manifold pressure, etc, so I can know what's going on with the car.
Hope you get it all worked out! Trust me, I know how frustrating it is!
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I installed a CM30 just a little bit ago on my car thats why me experience with it was so fresh. It is in front of the right front tire, all you have to remove is the inside fender guard and its right there. The hardest part of the install is getting the old clamps off of the hoses. After that its just off with the old on with the new. Buy some new hose clamps and some coolant. It is just plug and play other than that, I just cut wires and connected them with some clamps. No fancy harnesses or anything needed.
THANKS
thanks to all the members that have helped me with their suggestions. it turned out to be the ic pump after all. I replaced the pump myself with a johnson cm30 pump which cost me $145 shipped....so far so good![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
THANKS AGAIN!!!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
my car has the same problem but did not start until i replace my ic pump and then it start a couple hundred miles later it was solid until i put the johnson ic pump in
that's tricky I have issue where the gas surges at idle I bought a brand new accelerator pedal and when I hit gas nothing happens like pedal dead I'm wondering if there is a fuse I can check and replace it if popped?
