FS: C55 Sway Bars $200
Old Oct 16, 2009 | 09:10 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Fronts: 24mm/10mm end link hole
Rears: 15mm
Bigger and Stiffer than stock C32 sway bars.
Old Oct 16, 2009 | 09:39 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Rears: 15mm
Actually, I think C32 Sway bars are 22mm Front and 16mm Rear.
Old Oct 16, 2009 | 09:42 PM
AMGSC's Avatar
Yeah, the rears were most likely measured incorrectly. Should be 19mm.
btw...a small dia diff makes an exponential impact on stiffness and control.
Old Oct 17, 2009 | 05:50 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
sorry, but few facts
1. C55 actually has the same sway bar as the C32. 22mm front and 16mm rear.
2. if you have the 26mm and 19mm you probably have the H&R sway bar.
3. both C32 and C55 have 12mm endlink. don't know how did you get them in 10mm endlink.
Old Oct 17, 2009 | 01:40 PM
AMGSC's Avatar
Thanks for the correction again. My shop acknowledged he may have measured at the bends on the front and simply needs to remeasure the rears.
Most likely you are right that the C55 sway bars are 22/16 and not 24/15.
Do you know who makes the biggest sway bars? On your other post, you listed Brabus but are there others? Do you have a link where I can purchase them at a good price? I'm going to cancel my H&R order.
Old Oct 17, 2009 | 03:22 PM
2002 C32, 2012 S550
From another older thread:
"Available for the C32, we have the following:
Stock W203: F20/R13
StockC32: F22/R16
Evo: F24/R19
Eibach: F24/R22
H&R: F26/R19
The stock sedan bars have a 7 point spread between the front and rear bars. The C32 bars have a 6 point spread. The Evosport's have 5 points, the Eibach, 2 points, and the H&R's 7 points. What point shall I make?..."
https://mbworld.org/forums/c32-amg-c55-amg-w203/74637-c32-sway-bar-thread.html
I think I've read before of someone buying the H&R Front and combining it with the Eibach Rear for the thickest possible combination(F26/R22). Not sure how it worked out though....
Old Oct 18, 2009 | 12:55 PM
AMGSC's Avatar
Stock W203: F20/R13
StockC32: F22/R16
Evo: F24/R19
Eibach: F24/R22
H&R: F26/R19
Maybe I can ask Tirerack if it would work but good suggestion if I can't find the Brabus setup.
