C32 Custom Intake
Subscribe
Jan 17, 2010 | 09:51 PM
  #176
The flex tubing was at Lowes, or Home Depot. Can't remember which, but it's 4" diameter vent tubing. You'll find it in the roofing section where you will also find the 6" to 4" metal adapter. There is also a 6" metallic enclosure that would probably be a better choice than PVC. I really had to work with that PVC, and a dremel to get it to fit correctly both in the engine bay, and over the filters.
Reply 0
Jan 18, 2010 | 12:23 AM
  #177
Keep in mind that none of this was plug and play. I did a lot of cutting, grinding, etc... Your intake design is good, except for how you're using those rubber couplers! (use metal pipe section), and if you can build a sealed enclosure up front that might work out better from a IAT standpoint. There's a lot of heat where I have placed the filters, but good shielding should prevent any heat transfer. Return those filters, and get the ones I got with open end. Definitely better flow.
Reply 0
Jan 18, 2010 | 05:54 PM
  #178
okay ill get on that but i dont know how i could build an enclosure for them, any ideas?
Reply 0
Jan 19, 2010 | 12:18 AM
  #179
My main tool for most custom projects is a dremel...
Reply 0
Jan 19, 2010 | 10:48 AM
  #180
All a real man needs is a leatherman.
Reply 0
Subscribe
Currently Active Users (1)
