C55 Issues - Low Voltage to MAF Sensor
Old Dec 17, 2009 | 03:08 PM
Phil C55's Avatar
2006 C55 AMG White/Ash
Originally Posted by alpha8a
Phil, I am out of town and I do not have access to my manuals. I'm also not even sure if I have that warranty book as I got the car used. When I called the 1800 MB number, the lady said she was looking at the warranty booklet and could not find the MAF listed under what was covered by the FED. She, along with a few other service advisers, said only the catalytic converters, engine management sytstem, and a few other things were covered. Is there anyway you could post of send me a pic or scan of that specific page?
Hey Andrew, No problem, it's listed but they actually spell out the acronym and call it the mass air flow sensor, but it's in the 8 year 80k mile parts listed. There are a select few parts listed that apply to the California, Maine and Vermont cars but since you are in Mich. it should be covered. My warranty book is at home, but I can take a pic of the page and post it. I'd call back and have her check for a mass air flow sensor, it's there.
Old Dec 17, 2009 | 06:33 PM
Tump43's Avatar
2014 E350 4Matic
Originally Posted by Tump43
Jeff
I agree. The car is fine so far. It seems, however, that I need to get you to do my throttle body sooner rather than later. My dash dyno readings at idle and in Drive are substantially similar and are:
Intake Manifold Pressure: 10.9 in/HG
Intake Air Flow, MAF: 0.61 lb/min
Ignition Timing: -15.0 deg. BTC
Engine RPM: 537 to 549
I'll see if I can escape my wife's notice and get you the TB soon!! (In my house it is verbotten to spend money on anything other than shoes, boots, purses, lingerie or jeans and it is a capital offense soup up an AMG (assuming I have been forgiven for buying it in the first place)).
Update: I found a C55 throttle body at Potomac German Auto and am having it sent to Jeff to be bored out to fit the bored out elbow and MAF. The car has not stumbled in three weeks -- I still believe that by not properly snuging up all the various air delivery components I caused the stalling issues by creating a leak in the air intake system. Anyway, when I get the modified throttle body installed I will dyno the car and update everyone about the the benefits of these mods. Oh, with skinny winter tires 235 rear (235 front) my car can barely take off without spinning the rears -- my mods have overwhelmed its maximum winter traction on dry roads.
Also, I will research the federal emissions warranty covering the MAF.
Old Dec 17, 2009 | 06:59 PM
Tump43's Avatar
2014 E350 4Matic
Originally Posted by Phil C55
Yes I do, it's my 2006 MB warranty book that came with the car. In the Fed emmisions section there is a page that lists components that are covered and the MAF is listed. Do you have the books that came with your car?
Phil is correct. Please see p.37 (pic. 4, below) of the MB MY 2005 gasoline engine passenger car list of "Warranted Emission Related Components".
Old Dec 17, 2009 | 07:11 PM
Phil C55's Avatar
Thanks, now I don't have to resize the pics I took.
Old Dec 18, 2009 | 03:57 AM
alpha8a's Avatar
'05 C55 AMG
Wow thanks a lot Marc for the scans. I'm glad to see that it really does say "mass air flow sensor" there in print. There's no denying that once I show them. Should I call the service adviser back and tell him that it says it right in the manual that it should be covered?
Old Jan 4, 2010 | 08:58 PM
alpha8a's Avatar
'05 C55 AMG
I just looked at the PDF scans again and it says that the parts listed are only covered for 2 years/24,000 miles except for the parts with the stars next to them. Only the parts with the stars are covered for 8 years/80,000 miles.
Old Jan 4, 2010 | 09:26 PM
  #32
willc55's Avatar
2009 Mini Cooper Clubman S
Correct, only the starred parts are covered for 80k, everything else you are SOL which I discovered when I just had my CPS replaced after 63k
Old Jan 13, 2010 | 11:43 PM
  #33
alpha8a's Avatar
'05 C55 AMG
UPDATE: I purchased a new MAF from AutohausAZ for $135 and replaced it this afternoon. Everything is working perfectly now the car drives like new. Thanks for the help guys.
