My next Step....
Old Sep 14, 2010 | 07:29 PM
german32er's Avatar
C32 & C63PP, 203CL
Originally Posted by Robert AMG
I did before some search about this project, it is time and money consuming and a lot of work.
you need to get first 6 pistons and rods from an 55k engine, then a 350 motor beside your c32 engine, disassemble the 2 engines to the last bolt, and assemble one engine consisting of:
- c32 crankshaft
- 55k piston and rods
- 350 cylinder
- 350 heads including c32 camshafts and valve springs.
At the end you don't know what compression you will have(you need 9:1)
and you will get lower lower boost.
Get a wet nitrous 50-70 shot below 1k$ and you will get same or more result.
That is precisely the problem, the effort is quite large. therefore, look well to go so my C63 ....
with the C32 crankshaft in the 3.7L block are missing connecting rod with piston & 55k 4mm high ..... that goes together so not because others have Pleul pure.
with the 91mm stroke BRABUS crankshaft missing only 0.5mm .... that would be feasible, but still needed because of the 3.7L block very expensive.
I'm not sure how well the "online translator" to translate this text, so I let the original in German are also here.
@ Robert AMG, "we need the exact part nb on the sc inlet he showed us."
this part isn`t a MB part, ich have no nummer......
genau das ist das problem, der aufwand ist doch recht gross. daher gehen ja meine blicke auch zum C63....
mit der C32 kurbelwelle im 3.7L block fehlen mit den 55k kolben & pleul ca. 4mm kompresionshöhe..... das geht so nicht zusammen, da müssen andere pleul rein.
mit der brabus 91mm hub kurbelwelle fehlen nur 0.5mm.... das wäre machbar, aber eben doch aufgrund des benötigten 3.7l block sehr aufwendig.
Old Sep 15, 2010 | 10:25 AM
loudandheard's Avatar
C32/C55 AMG
So where did you get the SC inlet from, was it custom made? I have heard that there is a SC inlet that is a true 80mm and it is from mercedes.
Old Sep 15, 2010 | 11:29 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
since i have a spare c32 block. Can i just increase the bore from 89.9 to 97mm and keep the stock stroke and crank.
My plan was just to increase the bore to 3.7L and use custom forged piston and rods. then just reuse the c32 heads.
I think it might be cheaper just bore the stock block rather then buying another block.
Old Sep 15, 2010 | 07:04 PM
german32er's Avatar
C32 & C63PP, 203CL
sorry, i have no number, it is a "develop-part" from a tuner. it was the only part that was available.
i thing the first jear from SL 55 have an 80mmTB and no bypassTB......, perhaps this is the right part
I have spoken with the chief from MKB, he sad, the normal M112.32 bore to 97mm you can only make an NA engine. for an supercharged engine are the sealing surfaces to small.
for an charged M112 3.7L you need necessarily an factory 3.7L.......
this is certainly the basis why brabus only 92mm bores, and the rest with the extended hub makes
the advantage of an original 3.7L is also have the heads with the big valves.
Old Sep 15, 2010 | 08:56 PM
C32/C55 AMG
Good info. Do you have a website or link to the tuner that makes the rear supercharger housing?
Old Sep 15, 2010 | 10:27 PM
TemjinX2's Avatar
hmmmm....is the reason you can only go up to 94mm because you need some space to resleeve the piston?
maybe just keep the oem head and upgrade to e55k valves like you were doing on your head.
I was thinking of boring out the block and upping the compression from 9.0 to 10.0 similar to the 335i engines to get more power per psi.
Old Oct 8, 2010 | 01:48 PM
  #32
german32er's Avatar
C32 & C63PP, 203CL
hello,
Today I reached six pistons M113K.
now only lacks a 112 972 engine block and the 4 liter M112K were on the way ....
Old Oct 8, 2010 | 03:32 PM
  #33
TemjinX2's Avatar
great news man...keep the updates coming..
Old Apr 26, 2011 | 08:24 PM
  #34
german32er's Avatar
C32 & C63PP, 203CL
hi,
it happened, yesterday I bought a C63PP
i think i uninstall the modifications on the 32er.
then would the ported heads with new cams, new springs, SLR valves, the large throttlebody and the associated housing, 3.7l Brabus crankshaft and the 6 55K pistons for sale .....
has anyone interested?
Old Apr 26, 2011 | 09:40 PM
  #35
C32/C55 AMG
hi,
Congrats on the new car, but it sad to see you move on. Your car had so much potential. I wish I could buy every thing from you, but I just purchased a new car as well.
A little off topic, but how did your larger throttlebody work out for you? Did you get any performance increase?
We need pics of the new car/.
Old May 3, 2011 | 01:26 PM
  #36
german32er's Avatar
C32 & C63PP, 203CL
yesterday I picked him up, he is so hot ...........
C63PP, MKB exhaust mod, EVOTECH ECU mod.
Old Nov 13, 2020 | 01:21 AM
  #37
german32er's Avatar
C32 & C63PP, 203CL
Years ago...... now until 2020 the 4.0L C32 learn to run......
