Forgestar
Old 03-07-2010, 01:15 PM
mkonei's Avatar
05 C55
Forgestar
Any C55 guys running the F14 wheels?
Old 03-08-2010, 12:37 AM
alpha8a's Avatar
'05 C55 AMG
I ordered a set around the beginning of February and they should be here on Thursday. I'll post some pics once I get them on. Hopefully they won't rub.
Old 03-08-2010, 03:10 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
Can't wait to see some pics ! What size did you end up ordering?
Old 03-08-2010, 03:18 AM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
22's? 19's would be more realistic I guess...
Old 03-08-2010, 09:36 AM
alpha8a's Avatar
'05 C55 AMG
I went with 19x8.5 fronts and 19x10 rears. I don't know what the offsets are yet as they were custom made for the car. Does anyone know what sizes are our lug bolts?
Old 03-08-2010, 11:58 AM
moosejaw's Avatar
none
How much they set you back?
Old 03-08-2010, 01:39 PM
alpha8a's Avatar
'05 C55 AMG
I got in on the GB special that One Autosport was running so $1400 shipped.
Old 03-08-2010, 06:13 PM
mkonei's Avatar
05 C55
19x10? damn....brave soul. pics please when you get them!
Old 03-08-2010, 06:39 PM
alpha8a's Avatar
'05 C55 AMG
I know I was unsure about the sizing too but Michael from One Autosport said that because these will have custom offsets from Forgestar, they should fit. The only other size was 19x9. Wouldn't that have been too skinny for the rear?
Old 03-08-2010, 07:09 PM
MBworld Guru
FrankW's Avatar
white and whiter
19x10's pretty normal. you'll have to shave some tabs from the impact strip inside the rear bumper that's about it. my Carlsson 1/16 BE was 19x10 in the rear.
Old 03-08-2010, 10:40 PM
mkonei's Avatar
05 C55
never thought that wide would fit back there. what width tire? im waiting on the pics of the F14s, to see if theyre what im looking for.
Old 03-08-2010, 10:52 PM
MBworld Guru
FrankW's Avatar
white and whiter
i had 265 on it.
my buddy has the f14 in 18" on his c240 with brabus kit. i'll see if i can get some pics from him..lol
Old 03-09-2010, 12:16 AM
alpha8a's Avatar
'05 C55 AMG
I'm going to run 235/35/19F and 265/30/19R.
Old 03-11-2010, 11:02 AM
alpha8a's Avatar
'05 C55 AMG
The wheels are being dropped off by UPS today and I will get them installed tomorrow. I'll post pics soon.
Old 03-11-2010, 12:44 PM
cdd
cdd's Avatar
It's interesting that F-Star doesn't have 19x9.5 size. They have 9.5 in both 18 and 20 inch diameters...
Old 03-11-2010, 05:43 PM
alpha8a's Avatar
'05 C55 AMG
So I just got the wheels off the UPS truck. I inspected them to see what kind of "custom" offsets they made the wheels for. There was no offset size on the inside of the wheels or anywhere but there was a label on the outside of one of the boxes that said the offset was 26mm. Isn't that WAYYYY to low to fit the C55?
Old 03-11-2010, 06:46 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I've read elsewhere that the box-label offset is not what the final wheel winds up being, so to not go by that figure.
Old 03-11-2010, 07:08 PM
MBworld Guru
FrankW's Avatar
white and whiter
I would test fit them on the car before you put any tires on it.
sounds to me more like they gave you CLK55 (209) fitment if that 26mm offset you see is for the rear wheel.
if it's on the front you'll be alright. I'm running et27 all around with my LMs on 8.5/9.5.
Old 03-11-2010, 11:29 PM
alpha8a's Avatar
'05 C55 AMG
Thanks for the help guys. I talked to Michael of One Autosport and he said the same thing about the label on the box not being the actual offset of the wheels. I'm still waiting for him to get back to me on what the actual offsets of the wheels are. Either way, I will find out if they fit or not tomorrow.
Old 03-11-2010, 11:34 PM
MBworld Guru
FrankW's Avatar
white and whiter
friend's car on 18x8 18x9...
Old 03-12-2010, 10:09 PM
alpha8a's Avatar
'05 C55 AMG
So I got the wheels put on today. At first, after test fitting (before putting tires on and actually mounting the wheels) it seemed that the wheels would not fit or it'd be a super tight fit. The wheels hit the inside fender liner but this was before the car was on the ground so I had a feeling that they'd clear after they were mounted on with tires and the car was dropped to the ground. After actually mounting the tires and wheels onto the car and lowering it, I found that there was just barely enough clearance.
The bolts that I previously posted in this link did not work with the car/wheels. They were too long but Discount Tire had some that worked out great. So far after driving with them on, seems like the car only rubs on really big bumps. Here are some pics from my iPhone. I'll get better pics once the weather clears up here and I can get the car cleaned.
Old 03-13-2010, 12:42 AM
gt4awd's Avatar
Looks very nice!
Old 03-13-2010, 03:46 AM
MBworld Guru
FrankW's Avatar
white and whiter
as long as you have clearance it should be okay. the rubbing sound should be from the impact strip tab. put on some tire shine and the next time you hear it rubs, stop and check if there are marks on the sidewall of the tire.
Old 03-13-2010, 10:44 AM
alpha8a's Avatar
'05 C55 AMG
So to get rid of the rubbing, how should I trim down the impact strips?
Old 03-18-2010, 08:38 PM
alpha8a's Avatar
'05 C55 AMG
Question guys....after driving with the wheels on for a day, I noticed that the car vibrated big time around 60-65 mph on the freeway. The vibrations were felt in the steering wheel so I assumed it had to do with the balancing of the wheels. I took it back to Discount Tire the day after to have it rebalanced. After that, the car still vibrated around 60-65 mph but much less.
I took it into Discount Tire again today for the 3rd balancing and it STILL vibrates a little between 60-65 mph. Do you guys have any idea why? Is it due to the tires being of lower grade or anything?
Quick Reply: Forgestar
