Anyone actually replaced C32 right side fuel pump?
1 Post
CLK 320, C32 AMG
Just opened the right side (passenger) fuel pump location and fuel pump doesn't look like the c320 fuel pump. Has similar white housing with a pump in the middle, but line inlets don't match and there is an additional exposed pump right next to it. Anyone ever tried to replace this unit?
Black 2002 C32 AMG
I wish someone would chime in here that knows for sure because I have the same issue. I tested pressure at the rail, tested rear relay and made sure the car can turnovber by spraying starter fluid in the TB. I just need to find out which pump to replace with the proper part numbers.
Black 2002 C32 AMG
Most sites show only one pump and that it works with so many other C class cars.
http://www.rockauto.com/catalog/rafr...1416912k977043
