Does anybody do their own service/oil change?
I'm a little confused as to why one wouldn't trust jack stands...they are rated much higher than you're putting on them...just jack the car up and put em in place, they aint' going anywhere, I've done 5 engine swaps, multiple trannies and have always used jack stands. Personally I HATE ramps...seen too many people have trouble getting up on them and have seen people forget to block it off ...I one time had to lift a car with all my might to keep weight off as someone fumbled with a jack after one rolled back on a guy (I take no part in how or why it occurred, just know that he was one who should have known better). All that said, some people swear by them, not me.
He'll burn that 1/2 a quart in no time at all.
I still have 1.5 qt left over from the change in case it gets a bit low, I remember seeing in here somewhere people getting dipsticks. What is the part # or proper length of our dipstick?
Also, I got my CEL checked and I cant remember what the code was but it was secondary air injection malfunction (right bank) something along those lines... any advice? I could see any hoses off or anything..
- he drained oil(fully?) then put 8.5 quarts...then an assumption that at that point he's only 1/2 over. I don't care what others got out of their cars, I'm gonna measure what I drained. (see ** below)...ever have a car that held less or more than what was listed in manual or than someone else with same vehicle?
- I beleive later he indicated it was reading OK now...but I didn't get the message that he let it settle long enough (thus my comment on that)....obviously there can be quite a difference when the oil settles.
**I'm sure he's probably fine, but even if I was 99.9% sure he was I'd still reccomend spending the 20 minutes to be sure.
BTW, are you saying that you siphoned ~8 liters of transmission fluid on a 722.6 transmission out thru the trans dipstick tube? I think that would be a first as about 1/2 of the fluid is trapped in the torque converter.
I only wish it had the same system for transmission and diff oil!
The filter is on the top of the engine on the front right hand side looking at the engine from the front bumper to the rear. As for the dip stick tube, which lacks a dip stick, should be in the center of the closer to the back, do not make the mistake of using the transmission tube, they should be labeled.
I'm not too sure where the drain plug is on the C55, but I bet it's close to the same spot as where the C32 drain plug is. You will have to remove both under panels and once that is done the drain plug should be right beneath the driver's seat area, of course underneath the car, I just mentioned that portion to give you a general idea where the plug would be.
Oil is 0w40 mobil synthetic European brand and you can get the oil filters from needswings.com, ebay, or the dealer. I think needswings has fairly good price and they have always been good with service. As for the pump, I would go with a mityvac, which can be had for less than $100.
Good Luck.
