springs for c32. h&r or renntech, or??
i see i see
yeah i have a SLIGHT rub at the rear driver side.
i have stock #3 spring pads...my rear spring pads had 3 notches/fins on the spring pad...but yeah..i wonder if i can now fit 275s at the rear with #4 rear spring pads.
#35
MBworld Guru
white and whiter
275, Rollnn have done it on his c230k, but I'm not sure if it's worth the hassle since you will have to camber it out and loose contact patch regardless.
#36
I was on 19x10 et35 in that pic and with 265/30. shaving the tabs from the impact strip solved the rubbing issue i had.
so u rubbed on the impact strip?? im rubbing on the metal clip that holds the rear fender and bumper together..ive shaved off just enough..i only rub on with people in that side of the rear...i need to shave off more.
and i guess ill stay with 265s
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#38
MBworld Guru
white and whiter
WOW thanks for the heads up frank!
and i guess ill stay with 265s![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
I have my coilover set at about 1-finger gap all around now as well.
#39
